compression results!
did a compression test today and came out with the following:
210 212 220 205
this is on a stock JDM B18C (GSR)
do these numbers sound good and is there anything i should be worried about?!
210 212 220 205
Re: compression results! (untitledsn41)
They look pretty good, but it's a 7% difference between the 205 and 220. Is it at 5% or 10% spread that you should be worried?
Re: compression results! (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">They look pretty good, but it's a 7% difference between the 205 and 220. Is it at 5% or 10% spread that you should be worried?
About 20%
About 20%
All Motor Mentor
1 Post
Those numbers look good, the one slightly higher cylinder may have a little carbon in it or something but check it again in a year like was said and see how everything looks.
Re: (_Project EJOne)
i was planning on sea foaming it anyway. i just want to see if it makes a diffenence with the numbers or not. not like it can hurt anything
Re: (untitledsn41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitledsn41 »</TD></TR><TR><TD CLASS="quote">i was planning on sea foaming it anyway. i just want to see if it makes a diffenence with the numbers or not. not like it can hurt anything </TD></TR></TABLE>
actually i heard that seafoam may lower the compression since it gets rid of all that bad stuff in your cylinders that MAY raise your cr.
