droping b18a1 in my ek
need help .. whats stuff need to be done .. its runing off an obd 2 ls harness already .. obd0 distributor plug been wired up with the obd 2 plug
need help dont need negative comment i know it and old motor but im pretty sure its gonna produce way more power then the y7 already in the car
came with pretty much every thing trans motor wire harness, mounts ,shift linkage and axles all for 500 bux
help
help
Unceasing Measure
Re: droping b18a1 in my ek (slow_SIvic)
...bolt it in, plug it up and go. What are you confused about? If the wiring's already kosher, you should be good to go just like any normal swap.
Assuming that you will be running an OBD2- OBD1 adapter harness for the ecu. YOu cannot run and OBD0 distributor with and OBD1 or OBD2 ecu. OBD0 distributors only work with OBD0 ecu.s good luck
pnoyboldstar
04-13-2007 09:13 AM
