b18b1 crx. won't run right
Old 11-19-2012, 06:39 AM
Awiechman's Avatar
Default b18b1 crx. won't run right
Hey guys so I bought a 1990 crx si with a b18b1 motor as a project car. It will run but when you first start it you gotta keep on the gas or else it will die. Then after about a minute it can run on its own but it runs all shitty. Then when you drive it it will misfire over 3000 rpm abductions backfire and die. Then it won't start up again. I checked the fuel filter, timing, and grounds so far.. anyone have an idea? Thanks
Old 11-19-2012, 08:41 PM
meda215's Avatar
ecu......wen ever my ecu doesn't read my chip correctly it goes into limp mode n won't go over 3k rpm......so try another ecu p75 perferbly
Posted from Honda-tech.com App for Android
Old 11-20-2012, 11:25 AM
Awiechman's Avatar
Default Re: b18b1 crx. won't run right
I checked it and it does have the p75. But it could not be reading right?
Old 11-20-2012, 11:36 AM
Keyboard Humorist
4drEF's Avatar
Are you getting a check engine light?
If so, what codes?
also check to make sure you timing belt is on correctly.
Old 11-28-2012, 05:34 AM
Awiechman's Avatar
Sorry i forgot to add it also has an skunk 2 70mm throttle body, and a skunk2 upper intake manifold. could this be a problem?
Old 11-30-2012, 08:34 AM
crazy mad murdock
csingham's Avatar
ECU codes..help
last time you cleaned out IVAC.
connections on the TPS intact from transfer or new one used?
mostly read the ecu and it should pin point the area to look at. your on a good start since it has everything to start
Old 12-13-2012, 05:49 PM
Awiechman's Avatar
I just checked the ecu and it's throwing code 1 which is heated oxygen sensor. Could this be the problem?
Old 12-14-2012, 07:19 AM
meda215's Avatar
try and check ur throttle position sensor.....test it
Old 12-14-2012, 07:23 AM
meda215's Avatar
http://www.clubintegra.com/board/showthread.php?t=21792 this link should help
Old 12-14-2012, 06:15 PM
hybridmiklo's Avatar
a bad o2 sensor will ruin your day!! I had one in my bseries ef and i would hesitate like crazy driving. and if thats the cel you need to start there. stop playing around guessing at playing with other sensors. Start with the cel.
Old 12-14-2012, 09:02 PM
Awiechman's Avatar
Cleaned out the throttle body and started it up. Idle low and rough. After awhile the idle goes up to normal but still a little rough. Air/fuel is definatly off
Old 12-14-2012, 09:03 PM
Awiechman's Avatar
What o2 sensor is recommended?
WT-EF
12-22-2009 09:35 AM
CivicK20
01-14-2007 08:36 PM
40oztoFreedom
10
05-25-2005 06:14 PM
GEO276
04-29-2005 12:37 PM
Vp Special K
03-30-2003 09:56 AM
Quick Reply: b18b1 crx. won't run right
