b16a2 wiring ?
b16a2 wiring ?
i bought a wiring harness for my swap it has does not have the crank flactuicion sensor harness or nothing connected to those slots in the ecu .should i add them?
1 Post
Re: b16a2 wiring ? (jcivic)
Here are some things that you need to know:
1. You can't use the 99-00 B16 ecu in a 96-98 civic without using a conversion harness.
2. You can only use a 96-98 civic wiring harness (Ex harness is what you need).
If you get an ex wiring harness, you won't have to worry about the crank fluxuation sensor seeing that it's already on the harness.
From what I get, you're trying to use an OBD1 engine harness. It's not possible, you need either use your dx harness and add a couple wires or find an ex and extend the ones you need to.
Re: b16a2 wiring ? (fowler)
im using an 99-00 Si harness and ecu to run my LsVtec(OBDII setup). You have to do some rewiring but I recommend getting a conversion harness. Should be plug and play.
Re: b16a2 wiring ? (tnbigdawg)
i put a b16a2 into my 97 coupe si-g... i had to change the engine harness and harness behind the dash to the 00 si harness and it was all plug and play
EKcivicEK
10-25-2009 09:00 AM
NegativeXero
06-01-2007 10:37 AM
