b16a swap
Old 06-27-2003, 04:05 PM
Nikon169's Avatar
Default b16a swap
Just remembered, i was originally looking to do a b16a swap (obd o from 88-91? or 92...?) swap (it's on hmotorsonline's site, 1150 swap) into my 94 civic dx. they siad it wont bolt right in. does this mean i woudl need new motor mounts or what? what would i need to make this work, or will it? I could really use the $1000 that i'd save getting this engine but if it's a lot of work and shiz, ill get the 2299 swap (SiR 2) from hmotors. any input helps, thanks
Old 06-27-2003, 04:24 PM
Turbogixxer's Avatar
Default Re: b16a swap (Nikon169)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikon169 &raquo;</TD></TR><TR><TD CLASS="quote">(obd o from 88-91? or 92...?)</TD></TR></TABLE>
88-91 OBD 0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikon169 &raquo;</TD></TR><TR><TD CLASS="quote">(it's on hmotorsonline's site, 1150 swap)</TD></TR></TABLE>
Thats for a 1st Gen swap ( 1 million series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikon169 &raquo;</TD></TR><TR><TD CLASS="quote"> they siad it wont bolt right in. does this mean i woudl need new motor mounts or what? what would i need to make this work, or will it?</TD></TR></TABLE>
No, it will not. The trans is a cable and your is hydro. You need to get the a Hasport hydro to Cable (if it is out) or get a Hydro trans. The older motors will have more miles and/or sit in a junkyard for longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikon169 &raquo;</TD></TR><TR><TD CLASS="quote"> I could really use the $1000 that i'd save getting this engine but if it's a lot of work and shiz, ill get the 2299 swap (SiR 2) from hmotors. any input helps, thanks</TD></TR></TABLE>
Well, You can make it work, but it is have much of a hassle you want. You have to sell the Trans and axles (and other stuff). I would just get the SiR II swap.
Old 06-28-2003, 05:15 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikon169 &raquo;</TD></TR><TR><TD CLASS="quote">I could really use the $1000 that i'd save getting this engine but if it's a lot of work and shiz, ill get the 2299 swap (SiR 2) from hmotors. any input helps, thanks</TD></TR></TABLE>
Listen to turbogixxer. You WILL NOT save $1000 after buying all the necessary parts to make the motor fit and operate properly. Just buy the second gen B16A hydro swap.
Old 07-01-2003, 03:32 AM
Davep's Avatar
Default Re: b16a swap (turbogixxer)
1st gen swaps can also be 5 million series.
How do you know it's an 'SIRII' swap by looking at it? Since you can get a 91 civic SiR II and a 95 civic SiR II.
Get the right swap for your car and get the OBD1/hydro B16A.
hondachance
31
07-26-2008 10:46 AM
VtecHachi
06-15-2007 09:14 PM
tallyturbo
01-03-2006 03:19 PM
civic_on_13s
08-25-2003 11:38 AM
mugenwannabe
18
04-16-2003 06:06 PM
Quick Reply: b16a swap
