axle problems
axle problems
i just swaped a d16y7 into my ek, its my first swap i did all myself, i got everything good to go and running but now my passenger side axle will not come all the way thru the rotor. i dont know why it will not. any suggestions?
Re: axle problems
the axle shouldnt be too short then... are you sure you have the hub pushed all the way back? i have had a similar problem before but it was just getting hung up
Re: axle problems
it might be that ill check tomorrow..im pretty sure i do tho. if it wasent a d series axle would it fit into the transmission?
Re: axle problems
I just replaced my axles on my 99 civic LX, I had similar problems. There was black paint sprayed on the wheel end of the axle from the rebuild. I took axle out again, wire brushed the paint off the axle ends. Then put some motor oil on both ends before replacing. Wheel side of axle was still a bit difficult to go in. Held hands at 3 & 9 o'clock positions on brake rotor and shook rotor back & forth and axle went right in/together. Make sure you ONLY PUSH or PULL on the center of the axle shaft if replacing or removing; axle may come apart if you push or pull on the ends.
eggsi619
10-13-2022 02:57 PM
swarley
Transmission & Drivetrain
01-28-2011 06:56 AM
ev13lf
10-30-2008 06:59 AM
