on average how long does it take to pull a motor?
Old Feb 27, 2003 | 03:25 PM
mugensport9's Avatar
Default on average how long does it take to pull a motor?
on average how long does it take to pull a motor? and with a few guys, with no experience in pulling motors?
Old Feb 27, 2003 | 04:20 PM
keebler65's Avatar
Default Re: on average how long does it take to pull a motor? (mugensport9)
no experience should take around 1 - 3 hours unless you get some really siezed bolts or something like that.
Old Feb 27, 2003 | 09:31 PM
civicrtype's Avatar
Default Re: on average how long does it take to pull a motor? (keebler65)
My first swap was done a couple of weeks ago in my 98 hb. I dropped a b18b. It's pretty easy and straight forward, took me 4hrs too pull the motor out, but it was in 25 degree NYC weather with about 6inches of snow on the ground (did it in my friends back yard. Using just a 148pc Craftsman tool set and other misc. hand tools. No air compressor, no power tools, no engine hoist (did the ghetto pull engine out from the bottom deal).
Old Feb 27, 2003 | 09:57 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: on average how long does it take to pull a motor? (civicrtype)
my first motor pull was acomplished in 52 minutes, woohoo!
Old Feb 27, 2003 | 10:03 PM
owen_the_soyboy's Avatar
could take you 5 hours working with one friend if you dont know what yer doing.
could take you one hour if you have done it before and everything comes out a-ok.
Old Feb 27, 2003 | 10:28 PM
AB16A2T's Avatar
Default Re: on average how long does it take to pull a motor? (owen_the_soyboy)
I didn't know jack **** on what I was doing when I took my D16Y8 out and it took me about an 90 minutes or so. I was pleased with how quick it went, considering the driver's side axle was being a *****...
Old Feb 28, 2003 | 02:17 AM
43MA's Avatar
2.5hrs with handtools
focking easy
you'll get spoiled working on honda's
no other manufacturer is that easy
Old Feb 28, 2003 | 02:26 AM
paulzy's Avatar
Default Re: on average how long does it take to pull a motor? (Steady)
takes about 1 hour for just myself pulling it out
Old Feb 28, 2003 | 07:14 AM
Daemione's Avatar
I think it's pretty dependent on the tools you have at your disposal.
In other words, do you have an engine hoist and/or lift, or are you gonna be lifting it out with a team of camels & some rope? Air tools or a Bob Vila grip-it wrench? Good penetrating spray, or a stick of butter & a microwave?
Old Feb 28, 2003 | 08:22 AM
dkasakitis's Avatar
It could easily take a half a day or more depending on the car. Some things can really hold you up. Take for example the axles. You're supposed to removed the lower ball joint. If they are jammed and you don't have the proper tool that could easily take you an hour of banging and wedging. Are you removing the CAT? If so you can figure another hour (unless you can cut it out with a torch). How about your old motor, are you looking to sell it or is is trash you don't car about. If you do care you might be moving odds and ends like throttle body / TPS, distributor, etc. to prevent it from being damaged. Does your car have A/C or power steering. If so that can hold you up. Are you going to mark all the connections? Or are you going to hope you can remember where they all go? Are you replacing the shif arms? If so figure more time.
I'd say first time, trying not to damage stuff, marking all connections, storing the fasteners (nuts & bolts), removing items to gain good clearance, etc. it would take about 3-4 hours.
Dave K.
Old Feb 28, 2003 | 08:56 AM
5thgenjon's Avatar
Default Re: on average how long does it take to pull a motor? (dkasakitis)
Air tools and Honda engine pulling couldn't be easier!
Thats a huge benefit to these cars is how everything is so easy to work on.
Old Feb 28, 2003 | 11:17 AM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: on average how long does it take to pull a motor? (5thgenjon)
woth a cherry picker, hand tools, and no need to keep most of the engine parts= fast time!!!(hour-2.5 hours) putting stuff back is always the hard part!
just take your time, dont rush and ruin stuff!
edit: keep the castle nut on the ball joint when you are hitting the LCA to help prevent you messing up the threads
[Modified by TypeOne Enjoy It, 8:18 PM 2/28/2003]
Old Mar 3, 2003 | 08:32 PM
redzcstandardhatch's Avatar
something different
Default Re: on average how long does it take to pull a motor? (TypeOne Enjoy It)
pulling a 93 prelude motor without air tools and with stuck bolts took me about 8 hours or so......it sucked really bad, it was really cold outside and the garage had no insulation and no heat....it was only good to block the wind. preludes are really really complicated.....i'll take a civic any day of the week. super easy.
Old Mar 4, 2003 | 09:23 AM
ef ect's Avatar
Default Re: on average how long does it take to pull a motor? (redzcstandardhatch)
had the stock moter out of my 97 hatch out in 45 min but i had broke the axel nuts off befor putting it on jack stands. This is two people with two sets of tools and a cherry picker. But we are use to workin on his nissan and this honda was pie. but luckly enough no stuck bolts on the exaust!!
Old Mar 4, 2003 | 05:32 PM
swaplighter's Avatar
very true about the tools at your disposal...
i work at a dealer so its pretty straight forward..about an hour.
now without all these luxuries, in a crappy house garage and no air...about 3.5 or so...BTW,preludes suck to work on.
GSaura
Jul 31, 2009 05:44 PM
KL14
42
Dec 9, 2005 04:28 PM
civiccoupe94
Jul 17, 2005 12:48 PM
Glen Tennis
10
Dec 9, 2003 12:55 AM
mugensport9
Feb 28, 2003 12:51 PM
