OBD2 to OBD1
Old May 14, 2004 | 10:19 AM
DOHCon15s's Avatar
Default OBD2 to OBD1
If i use a harness that is made for a gsr, will it work for my ls. to convert it from OBD2 to Obd1
Modified by DOHCon15s at 7:42 PM 5/14/2004
Old May 14, 2004 | 10:20 AM
LSTEG96's Avatar
Default Re: OBD2 to OBD1 (DOHCon15s)
harnesses from a 96-98 gsr are the EXACT SAME as the ls ones from the same years...i use an ls harness and gsr ecu... dont worry, itll work.
Old May 14, 2004 | 10:34 AM
DOHCon15s's Avatar
Default Re: OBD2 to OBD1 (LSTEG96)
I have a 96 ls engine and I need to convert it into a OBD1- will this work for a harness?
http://cgi.ebay.com/ebaymotors...=WDVW
Old May 14, 2004 | 10:36 AM
stevieteg's Avatar
It works just fine. I have a 1995 gsr motor in my 1997 ls. Use the obd1 ecu, you'll need a obd2<obd1 conversion harness. You'll also need to wire vtec, knock sensor, and the secondaries for the im. FYI: it's illegal to have an obd1 motor in an obd2 car. If you plan on passing emissions you'll need to add a ckf sensor, which requires a obd2 oil pump and the senor itself, as well as an obd2 ecu of course.
Old May 14, 2004 | 10:39 AM
stevieteg's Avatar
Default Re: OBD2 to OBD1 (stevieteg)
Now I see your problem, it wasn't very clear in the first question. You'll need to run an obd1 ecu for it to work, becuase i don't think they make obd1>obd2 conversion harness.
Old May 14, 2004 | 10:41 AM
DOHCon15s's Avatar
The harness i might buy is for a 2000 gsr and i need to use it for my 96 ls to convert it to OBD1, I was just wondering if everything will fit right up
Old May 14, 2004 | 10:46 AM
stevieteg's Avatar
yes, it will work.
Old May 14, 2004 | 10:49 AM
DOHCon15s's Avatar
ok thanks, phew
Old May 14, 2004 | 08:56 PM
jentegraGS-R's Avatar
i think the obd2 harnesses for a 2000 gsr are different than the 96-99.
Old May 14, 2004 | 08:59 PM
Cramerox's Avatar
Default Re: OBD2 to OBD1 (jentegraGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jentegraGS-R &raquo;</TD></TR><TR><TD CLASS="quote">i think the obd2 harnesses for a 2000 gsr are different than the 96-99. </TD></TR></TABLE>
DING DING DING yes you are correct sir...there are obdIIA and OBDIIB wich requires differnt harnest.
its 96-99 and 00-01
mindless4banger
Engine Management and Tuning
Feb 28, 2016 12:50 PM
miamihonda
Dec 27, 2013 01:33 AM
recon23
Jul 17, 2009 09:31 PM
screen_name
Apr 22, 2006 06:56 PM
tig3rxiong
Jul 7, 2005 08:14 PM
