Fitting on rear of block?
Old Dec 25, 2001 | 09:37 PM
HX_Guy's Avatar
Default Fitting on rear of block?
I know the fitting is a BSPT but does anyone here use a NPT? Does it work/fit?
I was using a BSPT for my oil pressure gauge, but the hole in the fitting is like 1/16" amd I want it bigger for my VTEC feed line. Can I use a 1/8" NPT? Should I try and drill out the BSPT hole so its bigger?
Old Dec 25, 2001 | 09:43 PM
sgT's Avatar
sgT
Default Re: Fitting on rear of block? (HX_Guy)
I use 1/8" NPT all the time.
Its probably cross threading a bit, but doesnt leak or cause any problems.
Old Dec 25, 2001 | 10:08 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Fitting on rear of block? (sgT)
It is like one thread off, but Ive had no problems with it. Now, if Im not mistaken
Z10 makes a tee fitting that has the correct thread.
Copied from the the z10 website.
-Use true npt threads on the back of your block
-Stop ruining the threads on your head/block
-No risk of cracking/breaking off like bronze equivalents
-Made of 316 Stainless steel
-Use for Vtec, turbo, oil pressure gauge, or oil pressure switch
Old Dec 25, 2001 | 10:19 PM
JM Performance's Avatar
Default Re: Fitting on rear of block? (Arturbo)
I have that fitting. Works great. A little expensive, but it does its job: makes a nice seat and doesn't mess up any threads.
HX_Guy's Avatar
Well I know about that firring from Z10..but its like $13 plus Id have to wait
I need this ASAP. I guess Ill try a 1/8" NPT.
What do you guys think about trying to drill out the BSPT fitting I already have?
[Modified by HX_Guy, 11:20 PM 12/25/2001]
Old Dec 25, 2001 | 10:56 PM
sgT's Avatar
sgT
Drill out the fitting? just throw a NPT fitting in it.
Old Dec 26, 2001 | 08:31 AM
HX_Guy's Avatar
Ive eard from some people that they have had problems with the NPT fitting, it either leaked or broke off since it doesnt thread all the way into the block.
A local shop suggested to re-tap the block with for a NPT style thread...or redrill my BSPT fitting to 1/8". Ill try that...nothing to lose there.
Old Dec 26, 2001 | 11:01 AM
paulzy's Avatar
I used NPT, never leaked or anything...knock on wood
Old Dec 26, 2001 | 12:24 PM
TurboInteg95's Avatar
I've had the NPT fitting on my block for like 2 years now. although I might get that Z10 adapter just cuz I'm **** like that.
Old Dec 26, 2001 | 12:38 PM
TurboSedan's Avatar
New User
Default Re: Fitting on rear of block? (TurboInteg95)
Hey, I am ****-retentive!!! I am getting the Z10 fitting!!!
Old Dec 26, 2001 | 12:50 PM
HX_Guy's Avatar
Default Re: Fitting on rear of block? (97CivicFerio)
The ysell the fitting at Pep Boys..that is where I got mine. But like I said, the hole in the fitting is quite small in comaprrison to a true 1/8" NPT.
The hole in the 1/8" BSPT fitting looks to be slightly over 1/16" in size while a 1/8" NPT fitting hole looks closer to 3/16".
Anyone know teh size of the hole in the Z10 fitting?
standbackimapro
Oct 25, 2006 08:31 PM
2k1_ITR_0736
Aug 8, 2002 07:20 AM
92SiTurbo
Feb 28, 2002 05:39 AM
HX_Guy
Dec 26, 2001 06:30 AM
HX_Guy
Dec 24, 2001 11:03 PM
