b20/vtec turbo people
Re: b20/vtec turbo people (gsR-T mode)
i have heard some people getting their oil supply line from the vtec solenoid so i would imagine that you could run the sending line to there.
where did you hook your oil sender line to on the block?
I just T'd mine off the back.. makes a huge cluster of T's on the backof the block. I am going to run a line from the block to the T's to relieve the pressure off the block. I am still thinkin about the Z10 oil pump adapter.
-jay
[Modified by djdxm, 9:24 PM 6/24/2002]
where would you find the fitting to do that at the bottom of the block? any part #?
Re: b20/vtec turbo people (SlowB16)
Awesome, I have tried to seach everywhere for hybrids w/ turbos for this exact question. Because the same works for a lsvtec. I was wondering if it was too much of a strain there, if the pressure would still be alright.
Thanks for posting
Thanks for posting
Re: b20/vtec turbo people (Pelican)
-jay
[Modified by djdxm, 2:28 AM 6/25/2002]
in that case, wouldn't the VTEC solenoid be a suitable place for oil tap? also the oil will have to travel less, and wouldn't have to be split off in so many different directions. i've been running it from the VTEC solenoid for 5-6 months now.. no problem.
