has anyone ever heard of a low compression head gasket
i heard tha u can buy a head gasket that lowers your compression is there such head gasket like if so where can i buy one
Re: has anyone ever heard of a low compression head gasket (sick CD7)
who is king did u know any links that could show it that way i could google because i tried to google low compression head gasket but no luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick CD7 »</TD></TR><TR><TD CLASS="quote">yes its a thicker head gasket forget where but i think king had them awhile back </TD></TR></TABLE>
Yeah, thicker headgasket = lower compression, thinner = higher compression. Lowering the top of the head lowers the volume above the cylinder (raising compression) - that's why some people mill the head down, but be weary of where the cylinder head ends .
A lot of people take the Y8 stock 3 layer headgasket and pull the middle layer out to make it thinner, they pick up some compression that way.
What type of motor do you have?
Re: has anyone ever heard of a low compression head gasket (Ivan_JDM_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan_JDM_hatch »</TD></TR><TR><TD CLASS="quote">who is king did u know any links that could show it that way i could google because i tried to google low compression head gasket but no luck </TD></TR></TABLE>
There's a good compression ratio calculator but it's down right now.
D Series Compression Ratio Calculator
B Series Compression Ratio Calculator
Play with the headgaskets there - sorry if that B series doesn't work, the site is down right now ;crook:.
Re: has anyone ever heard of a low compression head gasket (Syndacate)
look i have a b18b1 turbo on a hatch the rings are going bad so i wanted to reaplace the rings but im going to ls vtec i know i will have more compression than a gsr motor
so i knowi need to lower the compression on it i cant buy low compressions pistons yet
i dont have the money yet but i have enought money to do ls vtec and rings but i want to lower the compression
Modified by Ivan_JDM_hatch at 12:36 AM 7/12/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan_JDM_hatch »</TD></TR><TR><TD CLASS="quote">none of those link works</TD></TR></TABLE>
Yeah, the site is usually up - but now the site is down, give it some time.
those head gaskets arent worth the money.
invest in a oem gasket and arp headstuds and your set no matter what compression.
b18, civic, compresion, compression, gasket, h22, head, headgasket, honda, low, lower, lowering, ratio, series, thicker
