innovative motor mount not fitting...
putting s b18 into my 98 civic. i went with innovative mounts and the drivers side motor mount, the metal bracket piece, doesnt line up with the bolt holes. if you line up the 2 lower holes the third top hole is short by about a half inch. has anyone ever had this problem? thanks
Re: innovative motor mount not fitting...
It does sound like you have the wrong mounts. As long as your car is not physically damaged and the weight of the engine is suspended by a jack the mounting holes and bolts should line up very easily. You shouldn't have to bend or reshape anything.
Three things are likely:
1. You ordered or received the wrong mount for your vehicle/engine combo
2. Your mount is bent or misshapen
3. You have the wrong mount on the wrong side of the motor??
fastcrx420
10-25-2009 04:48 AM
BryanPendleton
03-22-2006 07:57 AM
O16581724 5 2 5
05-30-2005 10:35 PM
