1st Gen B16a trans input shaft same as all B-series trannies?
basically i might be getting a CRX that i am going to keep with a b16 in it. my current car has has a 97 GSR swap with my JUN flywheel and ACT 6 puck clutch. i want to swap flywheels and clutchs,,,, WILL this work?> or are the number of splines different? thanks to all that respond
werd out http://images.zeroforum.com/smile/h-emblem1.gif http://images.zeroforum.com/smile/acura1.gif |
Re: 1st Gen B16a trans input shaft same as all B-series trannies? (JDM CRX)
it will fit
Re: 1st Gen B16a trans input shaft same as all B-series trannies? (1tyme)
the clutch is different if you use a cable tranny with the b16a.... you can swap your whole gsr swap in the crx with some work....
