Vtec check engine code
Old Feb 20, 2006 | 06:25 PM
88hatchef's Avatar
Default Vtec check engine code
I have a 92 Civic si with a B18c1 in it and lately when I hit vtec, my check engine light comes on. Its not always, if I just mildly accelerate and hit vtec it wont throw a code but if I bang a gear and it gets into high rpms, around 7 or 8 grand the light comes on and it disengages vtec. Any ideas as to what my problem is?
Old Feb 20, 2006 | 06:30 PM
lobudgetr's Avatar
Default Re: Vtec check engine code (88hatchef)
what code is it throwing?kind of important to know that part, could be knock sensor, could be oil pressure switch, maybe VTEC solenoid.
Old Feb 20, 2006 | 06:51 PM
88hatchef's Avatar
Code 22
Old Feb 21, 2006 | 01:38 PM
88hatchef's Avatar
Bump
Old Feb 21, 2006 | 01:42 PM
rollydc69's Avatar
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Old Feb 21, 2006 | 04:14 PM
BMaDOHC's Avatar
try cleaning the screen on the sylenoid with carb spray, if it don't work, jump 12 volts to it, it may be getting stuck
Old Feb 21, 2006 | 06:51 PM
88hatchef's Avatar
Ill have to look at the screen, I already am getting 12 volts, I have a msd applicator. One other thing Ive noticed lately which seems to be a bad sign is when I initially hit vtec, ive notice a big puff of blue smoke which would lead me to believe that either my valve seals are shot or bad rings.......however i did a compression test a few weeks ago and compression was around 240 on all cylinders(Type R Internals). I find it very strange that if I was burning oil it only seems to be in vtec........ideas????
Old Feb 22, 2006 | 12:59 PM
88hatchef's Avatar
Anybody?
Laz's EP
22
Feb 22, 2010 12:09 AM
93b20z
May 18, 2009 04:59 PM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
