00 si ecu codes...
Old 05-16-2003, 05:22 AM
2000CX's Avatar
Default 00 si ecu codes...
i searched and can't make any sense out of the codes that were listed. where can i get a full list of these newer model year codes?
i believe i am throwing a #6 and either #56 or #65????
Old 05-16-2003, 05:33 AM
2000CX's Avatar
Default Re: 00 si ecu codes... (2000CX)
ok...so i think i my have found the answer...just wanted to double check though...
code #6 ECT Sensor (Engine Coolant Temperature)...is this it?
code #65 Oxygen Sensor Heater (Secondary)...kinda figured that due to the fact that i do not have on hooked up
Old 05-16-2003, 07:44 AM
2000CX's Avatar
any ideas or comments?
Old 05-16-2003, 07:46 AM
fowler!'s Avatar
Did you just finish your swap? Do you have vtec right now?
Old 05-16-2003, 08:20 AM
2000CX's Avatar
Default Re: 00 si ecu codes... (fowler)
well i never had it with my previous motor, but i DO here this kinda loud whistling sound that i assume is vtec at around 4-4500...is that it?
Old 05-16-2003, 08:24 AM
fowler!'s Avatar
Probably not, seeing as a stock Civic Si vtec engages past 5k RPM.
Anyway, what I think you did is switched the ECT and the Vtec pressure switch... or the vtec solenoid. I forget which one that sensor matches.
In any case, try and switch them around. That should fix your problem if you actually have a code #6.
Old 05-16-2003, 06:11 PM
2000CX's Avatar
the rpm might be a little bit higher than i mentioned...i am still freaking out everytime i drive my car(my first swap) would anyone be able to get some close up shots of the location of these two sensors(ECT and the Vtec solenoid...i know some one is bored enough to grab some shots for me.
Old 05-17-2003, 06:18 AM
2000CX's Avatar
bump for more ideas...
Old 05-17-2003, 09:25 AM
2000CX's Avatar
anyone...still looking for location of ECT?
Old 05-17-2003, 10:07 AM
fowler!'s Avatar
brb...I'll go take a pic for you...
Old 05-17-2003, 10:14 AM
2000CX's Avatar
sweet...
Old 05-17-2003, 10:17 AM
fowler!'s Avatar
The ect sensor is directly under the vtec solenoid. You'll notice that the plug for the vtec pressure switch is the same exact style plug. They are very close to each other, so the chances of getting them mixed up is very high. Like I said before, switch them around, then reset your ecu. That should fix the problem if in fact you have a code 6
Old 05-17-2003, 10:19 AM
2000CX's Avatar
thanks man...i will check it out right now.
Civic plow
03-25-2016 10:31 AM
88_hatch_ls
05-11-2011 10:12 AM
1clean_ Ej
02-28-2007 08:07 PM
vtecpsyco
10-23-2005 11:18 PM
DumpedSi
09-08-2003 04:18 PM
Quick Reply: 00 si ecu codes...
