alternator problem
Old Jun 10, 2010 | 02:40 PM
jdmwarrior's Avatar
Default alternator problem
my EG with b series swap been having problem, everytime i turn on the a/c my engine died. do you think its because bad alternator? do u guys know what kind of alternator are we using, if i want to replace it? thanks it advance
Old Jun 10, 2010 | 05:15 PM
delsolproblems's Avatar
Default Re: alternator problem
Take it to a parts store and have them check the start & charging systems.
Old Jun 10, 2010 | 08:46 PM
honda_luvr_2000's Avatar
If the engine shuts right off as soon as you turn on the A/C, sounds like the problem is with the A/C compressor, not the alternator. If it has no running problems with the A/C off, headlights on, rear defog, radio, etc. then it's not an alternator issue at all.
Old Jun 11, 2010 | 05:38 AM
kyden's Avatar
sounds like you have a seized compressor.
Old Jun 11, 2010 | 09:10 AM
mouab18c1's Avatar
To check your alternator: Loosen your + side of your battery and turn on your car. Once the car is on take the + side off your battery; if the car dies then the alternator is dieing out. If not then its something with your a/c
EJ8_Man
May 25, 2019 10:21 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
macsmurray
12
Jun 14, 2005 02:36 AM
