Honda S2000 Honda S2000
test pipe help
Old Mar 13, 2007 | 09:47 AM
ReddotsS2K's Avatar
Default test pipe help
i bought a test pipe and put in on my car along with a mechanical o2 sim which is basically made out of bolts and the o2 screw into that. it worked for about 3 days and then the check engine light came up. so i hooked the obd2 up to it and deleted the codes and it came back a few hours later. has nayone else had this problem. should i get an electrical simulator?
Old Mar 13, 2007 | 09:53 AM
WowOzYouRock's Avatar
Default Re: test pipe help (ReddotsS2K)
make sure the tip clear from the exhaust stream .... or maybe the secondary o2 itself is faulty...
Old Mar 13, 2007 | 09:57 AM
Mr. Projekt's Avatar
* B A N N E D *
Did you bore the hole out on the smaller of the two spark plug anti-fouler pieces?
Old Mar 13, 2007 | 10:02 AM
Default Re: test pipe help (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Did you bore the hole out on the smaller of the two spark plug anti-fouler pieces?</TD></TR></TABLE>
if hes using the spark plug anti-fouler then im sure he bore it out or else it wouldnt fit... right?
Old Mar 13, 2007 | 10:03 AM
* B A N N E D *
Default Re: test pipe help (FR-MOB: Jerk)
Nah it fits. Just that the hole is too small sometimes and throws a lower voltage.
Old Mar 13, 2007 | 10:12 AM
i have to drill the anti-fouler i bought, regardless, cuz the tip wont fit...
Old Mar 13, 2007 | 10:36 AM
b20integrapower's Avatar
are you using one? or both of the anti-foulers? some threads will say to use only one, but use both to be sure.
Old Mar 13, 2007 | 01:20 PM
the soL that could's Avatar
If it’s a 07 like your membership, you’re fcuked… ap1 vs. ap2 have different part #’s for o2 sensors. The 07 is different than all others. Basically, the newer the S, the more difficult it is to fool the secondary.
I’m not sure what dictates what (the ecu or the sensor) you can try it out and tell me. I have an o7 but I sold my pipe for this very reason.
Old Mar 13, 2007 | 07:38 PM
ReddotsS2K's Avatar
yeah i have a 2001 ap1. i have two just like in the picture that is shown above. i do not know what you mean by "bore it out". what am i supposed to change?
Old Mar 13, 2007 | 07:54 PM
Mr. Lucky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have a 2001 ap1. i have two just like in the picture that is shown above. i do not know what you mean by "bore it out". what am i supposed to change? </TD></TR></TABLE>
for your top anti-fouler. take a 1/2 inch drill bit and go all the way through. that way your o2 sensor will sit right in it. you don't have to do the bottom one, it just acts as an extension.
Old Mar 14, 2007 | 03:31 AM
ReddotsS2K's Avatar
Default Re: test pipe help (Mr. Lucky)
i appreciate the help ill give it a try probally tonight.
Quickridez_3
Jan 23, 2014 05:26 PM
tusnamiep3
Aug 23, 2007 08:04 PM
gulftiresinc
Sep 18, 2004 09:55 AM
typer.org
Oct 5, 2002 12:59 AM
ITRacer121
Apr 12, 2002 04:13 PM
