Honda S2000 Honda S2000
supercharged with FD gears?
Old Sep 1, 2006 | 09:26 AM
lilbastrd's Avatar
Default supercharged with FD gears?
im looking into upgrading my gears with a 4.77 final drive but not really sure if its too short for the supercharged S2k. what do you guys think about it? should i go for a 4.44 FD instead?
thanks
Old Sep 1, 2006 | 09:42 AM
RacerXI's Avatar
Default Re: supercharged with FD gears? (lilbastrd)
I'd pass on 4.77's for a boosted car. 4.30's or 4.44's tops. Then again, why not just make more power?
Old Sep 1, 2006 | 09:46 AM
papa5murf's Avatar
to short for boosted cars... you'll be shifting like a maniac... besides, you'll be topping the car out quite quickly with the 4.77 gears...
4.44 max with boost...
Old Sep 1, 2006 | 03:56 PM
revhi's Avatar
I dont see how it matters the gears your choosing if your S/C or not. Youll be the same RPM range with the same set of gears going the same speed, boosted or not.
Old Sep 1, 2006 | 05:25 PM
WhiteAP1's Avatar
yes but u'll be getting through the rev range a hell of alot quicker with a s/c, so ud be shifting constanly. Same speed, same rev, just at a different time, ie: much earlier with a s/c
Old Sep 1, 2006 | 06:04 PM
Sideways's Avatar
As your power goes up you will need the gearing less. I ran the 4.44s for 3+ years and went back to the 4.10s this year. The 4.10s are considerably faster in the quarter mile with 450 rwhp.
I'm working on getting a set of 3.9s at this time.
Old Sep 1, 2006 | 06:16 PM
revhi's Avatar
You wont be getting through the gears that much faster unless your pushing Sideways power.
1/4 miles times will be faster with 4.10's for you. I know with 4.44's Im going into 5th before the end of the track. You must be in 5th 3/4 ways through even with 4.10's.
Still dont see how choosing gears really matters s/c or not unless your pushing over 400whp. I think 4.77's are to much for any S.
If I could do it again, Id get 4.56's.
Old Sep 2, 2006 | 03:12 PM
HighPsiAwd's Avatar
Default Re: (revhi)
Where can you purchase the 4.77s from? How much?
Old Sep 3, 2006 | 01:16 AM
WhiteAP1's Avatar
Default Re: (HighPsiAwd)
I found this thread extreamly helpfull for sourcing my gears. Got the Kia gears ready for install ATM.
http://www.s2ki.com/forums/ind...82172
Old Sep 3, 2006 | 05:22 AM
JSWhaler's Avatar
if you have an ap1 split the difference and get 4.57
Old Sep 3, 2006 | 11:33 PM
uNF$@#!'s Avatar
Default Re: (WhiteAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteAP1 &raquo;</TD></TR><TR><TD CLASS="quote">I found this thread extreamly helpfull for sourcing my gears. Got the Kia gears ready for install ATM.
http://www.s2ki.com/forums/ind...82172</TD></TR></TABLE>
really now...is that gear just the FD? dont you need a different first gear and shaft?
Old Sep 4, 2006 | 07:24 AM
WhiteAP1's Avatar
The link specifically refers to the ring and pinion in the diff. Its just like installing the ring and pinion J's racing or Ricks offer.It changes the gear ratio of the final drive. Dont know how first gear or "shaft" (which shaft??) come into it.
Modified by WhiteAP1 at 8:39 AM 9/4/2006
Old Sep 5, 2006 | 08:28 AM
gomarlins3's Avatar
I have a CT SC with 4.77's. Can't complain. I go through the low RPM's quickly and get to VTEC sooner. Anyone with a SC will tell you that there is no effect fromthe SC until you get to VTEC. The sooner you are there the better.
99CoupeEK
Feb 21, 2019 10:45 AM
2LiterTurboSeR
May 10, 2006 07:28 AM
Agent Zero
Honda S2000
11
Apr 5, 2006 07:37 AM
agordon
Nov 23, 2004 02:18 PM
91_hatch_si
13
May 8, 2003 10:59 AM
