Honda S2000 Honda S2000
hard top conversion?
Old Aug 8, 2006 | 09:17 AM
nelsmar's Avatar
Default hard top conversion?
when you buy a hard top from honda. do you have to remove the convertable? or can you just install the hard top on top. remove the hard top and put the convertable top on? how does that work? and how hard is it to take the hard top off? hard top look ssooooooo nice.
thanks guys!
Old Aug 8, 2006 | 12:32 PM
TheGrove's Avatar
Basicly you need two ppl to put the hardtop on, as far as installation you need the honda hardware. You can keep the softtop on the car while using the hardtop.
Old Aug 8, 2006 | 12:55 PM
VTECth1s's Avatar
Default Re: (TheGrove)
spending at least 3 g's for the oem hardtop plus another $$ for hardware parts...dang the price to be sleek.
Old Aug 8, 2006 | 01:05 PM
nelsmar's Avatar
is it sopsoed to be a permanint thing ... with ability to remove. or was it ideal to tke the top off on sunny days. what was the idea? was the hard top a straight replacement to make a perm roof? because ide like a hard top. but when i go on a road trip. i want to be able to take hte top town. and i know that thing isnt going to fit in the trunk
Old Aug 8, 2006 | 01:15 PM
papa5murf's Avatar
Default Re: (nelsmar)
you put the soft top down.. and put the hard top on ... you take the hard top off and you up the soft top up... simple as that...
Old Aug 8, 2006 | 01:36 PM
TomTomTuning's Avatar
Default Re: (papa5murf)
Oh wow.. thats cool (new to me)
I thought you had to remove the soft top completly when installing the hardtop.
I didnt know you could keep the softtop.
is that correct ?
Old Aug 8, 2006 | 02:17 PM
nelsmar's Avatar
how easy is it to put the top on though?
thanks guys thats what i was hoping you could do!
Old Aug 8, 2006 | 03:16 PM
cybergreencivic's Avatar
yes you keep the softtop. as to it being easy, ive read for the mugen one to expect a few hours for install and assume the oem one to be around the same. ill let someone here who actually has one give the deffinite answer. ive considered it, but for the money, and time to install i will invest in other parts for right now.
Old Aug 8, 2006 | 03:25 PM
papa5murf's Avatar
Default Re: (TomTomTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TomTomTuning &raquo;</TD></TR><TR><TD CLASS="quote">
is that correct ?</TD></TR></TABLE>
yes you can keep your soft top....
Old Aug 8, 2006 | 03:26 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nelsmar &raquo;</TD></TR><TR><TD CLASS="quote">how easy is it to put the top on though?
thanks guys thats what i was hoping you could do!</TD></TR></TABLE>
the top weighs around 42lbs.... so it's not heavy at all.. however it's quite large to get your arms around.....it's doable by yourself, but do you want to take the risk?....
Old Aug 8, 2006 | 03:27 PM
papa5murf's Avatar
Default Re: (cybergreencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cybergreencivic &raquo;</TD></TR><TR><TD CLASS="quote">yes you keep the softtop. as to it being easy, ive read for the mugen one to expect a few hours for install and assume the oem one to be around the same. ill let someone here who actually has one give the deffinite answer. ive considered it, but for the money, and time to install i will invest in other parts for right now. </TD></TR></TABLE>
installation isn't to hard... what makes it time consuming is aligning it properly...
Old Aug 8, 2006 | 04:59 PM
tk2068's Avatar
Default experience in installing a hardtop
I just bought a hardtop two weeks ago and installed it myself. Transporting the hardtop home is a pain since the box is huge (5.5' x 5' x 2') even though it weighs only about 120lbs. So pay somebody to deliver it to your doorstep.
Installation is very easy since the instruction is very clear and the steps involved are simple (if you know how to use a screwdriver, a ratchet, and are unafraid to pull things apart). For somebody who is mechanically-challenged like me, it took me a total of four hours to install.
To me, the most difficult step is to adjust the retainers since I had to hunt those wind noise but my cabin is pretty quiet now. I guess it could have been worse since I have read people complained about having to replace their front strikers due to wind noise so I feel pretty lucky.
The next most difficult step is, like someone mentioned earlier, is to align the the hardtop for the initial install. It is a pain because one has to loosen a total of 8 bolts, seats the hardtop, tighten the bolts, and repeating these steps until the hardtop is aligned properly. The cabin is small so moving around just get that much more difficult.
Now I can take off and put on my hardtop in about five minutes. I have done it a few times. Need two people or you will scratch your paint or worse.
Old Aug 8, 2006 | 07:04 PM
nelsmar's Avatar
so no quick disconects? its 8 bolts to remove after the initial isntall? looks like i got all the info i needed guys ty! while reading tk2068's post i was afrad it would take 4 hours each time. thatd be a pain.
thanks again guys!
Old Aug 9, 2006 | 01:32 AM
tk2068's Avatar
Default Re: experience in installing a hardtop (tk2068)
Sorry if the explanation on the 8 bolts was not clear. You need to mess around with the 8 bolts only during the initial install. Once you set those 8 bolts properly for your car (the 8 bolts secure the handle assembly, and the handle assembly is adjustable), from that point on, it would be very quick to take off and put on the top since there are quick releases.
Old Aug 9, 2006 | 05:47 AM
nelsmar's Avatar
oooo great. i appreciate the help :D
Old Aug 9, 2006 | 08:04 PM
alexS2000fan's Avatar
would it be quicker to do it at the honda dealer? how much would it cost?
Old Aug 9, 2006 | 08:39 PM
tk2068's Avatar
Default Re: (alexS2000fan)
It should be quicker. I was quoted $300+ (four hours labor) so I decided to do it myself and I was glad I did since I learnt a thing or two about my car. One big problem I can see when having the dealer do it for you is that you either have to buy the hardtop from the dealer itself (probably won't get the best price) or having to transport the hardtop to the dealer for installation.
Old Aug 9, 2006 | 09:31 PM
LAS2K's Avatar
Default Re: (tk2068)
unless you buy your hardtop from i think it was Flagstaff Arizona Honda for $2800 or something like that
Old Aug 10, 2006 | 08:11 AM
EGHatch94's Avatar
Default Re: (LAS2K)
Is that what I should expect tp pay for a hard top? I don't have an S2k yet, but will shortly...
Old Aug 10, 2006 | 10:53 AM
AP1's Avatar
AP1
buy used for ~2200 @ s2ki.com
Old Aug 10, 2006 | 12:58 PM
tk2068's Avatar
Default Re: (EGHatch94)
I was thinking about buying a used one, too, until I found out that many of them don't include the mounting kits since once mounted in the car, the kits are a bit of a pain to uninstall. Checking around, I saw people selling those mounting kits for hundreds of dollars. So try to get the seller to give you the mounting kit, too.
Old Aug 10, 2006 | 01:12 PM
Francesco's Avatar
Default Re: (AP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AP1 &raquo;</TD></TR><TR><TD CLASS="quote">buy used for ~2200 @ s2ki.com</TD></TR></TABLE>
I paid 1650$ for a used one with all the hardware 2 years ago
Old Aug 10, 2006 | 03:12 PM
CHILIBEANZ's Avatar
damn that's cheap. i got mine @ cost for $2700 and i ended up taking out the whole convertible assembley since i never really cared for the ragtop anyway.
Old Aug 10, 2006 | 04:13 PM
tk2068's Avatar
Default Re: (p220)
How long would it take to remove the entire convertible assembly for a novice? Was there any special tool needed? Thanks.
Old Aug 10, 2006 | 04:46 PM
Tyson's Avatar
Default Re: (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
I paid 1650$ for a used one with all the hardware 2 years ago </TD></TR></TABLE>
thats for used oem hardtop right?
what have ppl paid for a used mugen frp one?
