Honda S2000 Honda S2000
QUICK question.
Old Nov 12, 2007 | 02:46 PM
veilsides2000's Avatar
Default QUICK question.
I installed my Ek fogs into my s2k and wired everything up. They worked fine for about 2 days and now they don't work.
All the wires seem fine and the harness is good also.
Finally found out that the fog light switch took a **** on me.
My question is that I'm running 100w bulbs in there instead of the normal 55w.
Would those bulbs cause the switch to go out like that or was it just a bad switch?
Old Nov 12, 2007 | 06:33 PM
Black S2K's Avatar
Are you running a fuse?? Cause if your not the switch will keep taking ***** unless you get a bulky ugly one.
Old Nov 13, 2007 | 08:00 AM
Default Re: (Black S2K)
no fuse. But im installing one.
Should the bulbs really be changed out> What blbs are others on here running?
Old Nov 13, 2007 | 11:06 AM
s2kdre's Avatar
Default Re: (veilsides2000)
put a fuse in the system and see if it blows then.
Old Nov 14, 2007 | 06:59 AM
Its_real&its_spectacular's Avatar
New User
Default Re: (s2kdre)
No, the bulbs shouldn't overload the switch, there's a relay in the system. You may however, want to upgrade the wiring that goes to the bulbs... Run your own relay and bigger wires. I've seen big bulbs burn stock wires and stock harnesses...
Old Nov 15, 2007 | 07:33 AM
Black S2K's Avatar
he prolly ddint even use a relay cause hes not using a fuse.
Old Nov 15, 2007 | 08:15 AM
The relay comes with the harness.
Old Nov 15, 2007 | 08:30 AM
m R g S r's Avatar
thats weird because the relay should be preventing the load from going through the switch. . . .
are you sure everything is wired correctly?
Old Nov 15, 2007 | 08:42 AM
Default Re: (m R g S r)
Yeah im sure it's wired correctly. I know the bulbs are giving extra wattage and the switch was too weak to support it. I heard that the non OEm switches go out anyway.
I went out and bought a switch from mylocal autozone and i now it should be able to handle it.
Just gonna put a mini 10amp fuse in there to see if it blows.
My main concern is if the wiring will burn over time?
stinkypinky1011
21
Nov 11, 2013 11:18 PM
chrisff521
Mar 6, 2010 08:02 PM
Civic-Kids
Audio / Security / Video
Feb 22, 2010 10:30 AM
veilsides2000
Lighting
Nov 13, 2007 08:04 AM
hookem51
Honda Civic (2001 - 2005)
May 4, 2007 06:25 PM
