help with foglight
Old Feb 21, 2010 | 09:35 PM
Civic-Kids's Avatar
Default help with foglight
look at this pix:
i put the fuse between the battery to switch.. every time i test it, the fuse blew... i remove the fuse n connect it directly to the switch... what u guys think??? if anything goes wrong... the light bulb going blow?
Old Feb 21, 2010 | 09:41 PM
PoorBoy_96civic's Avatar
Default Re: help with foglight
if it blows then you have a short somewhere leave the fuse in and test it with out the switch and see if it still blows if it does then you have something wired up wrong or the fuse is to small
Old Feb 21, 2010 | 10:13 PM
kozanatos's Avatar
The fuse is telling you something, that there is a problem. What it is like a 30amp?
You could take apart your fog lights and make sure they are installed correctly. I had problems with mine. You should do that. Its really easy to and you will learn how to install bulbs for when you need to.
Old Feb 22, 2010 | 06:09 AM
fcm's Avatar
fcm
Old Fart
First off you should be using a relay.
As mentioned, check how the switch is wired, it is easy to mis-wire an illuminated switch, start by disconnecting the switch ground and see if fuse still blows. 94
Old Feb 22, 2010 | 10:30 AM
Civic-Kids's Avatar
ty for all ur help... i replace a new fuse with 30 amp work fine...
dc4teg95
Jul 27, 2013 02:07 PM
barone
Jun 4, 2011 07:21 AM
jdm206
11
Sep 17, 2007 11:59 AM
Fly1865
Jun 18, 2004 05:48 PM
