Lighting HID/Xenon kits, Retrofits and Associated Topics
Quick question.
Old Nov 12, 2007 | 02:47 PM
veilsides2000's Avatar
Default Quick question.
I installed my Ek fogs into my s2k and wired everything up. They worked fine for about 2 days and now they don't work.
All the wires seem fine and the harness is good also.
Finally found out that the fog light switch took a **** on me.
My question is that I'm running 100w bulbs in there instead of the normal 55w.
Would those bulbs cause the switch to go out like that or was it just a bad switch?
Old Nov 12, 2007 | 04:02 PM
androO's Avatar
Default Re: Quick question. (veilsides2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 &raquo;</TD></TR><TR><TD CLASS="quote">I installed my Ek fogs into my s2k and wired everything up. They worked fine for about 2 days and now they don't work.
Would those bulbs cause the switch to go out like that or was it just a bad switch?</TD></TR></TABLE>
check your wires dude. make sure they can handle the current. are the gauge big enough?
as far as switches go I'm sure that could be a possibility as well. go to radio shack and try a bigger switch. its definitely worth the test.
Old Nov 12, 2007 | 05:40 PM
bpr0422's Avatar
if you wired it right, the switch shouldn't see an amp load larger than 1 amp.
Taken from here: https://honda-tech.com/zerothread/1812043
I want to redo that diagram.. so that the switched in, is wired directly to the battery.
Old Nov 13, 2007 | 08:04 AM
Default Re: Quick question. (bpr0422)
should my wires be able to handle the bulbs? I got a new and bigger switch
tyronne1126
Mar 18, 2009 08:01 AM
veilsides2000
Honda S2000
Nov 15, 2007 08:42 AM
veilsides2000
Nov 14, 2007 08:00 AM
6shootahorsenamedtrigga
Acura TSX
May 31, 2006 11:32 AM
