Honda S2000 Honda S2000
Oil Question
Old Nov 23, 2008 | 01:18 PM
DO_ITR_YoungD_19's Avatar
Default Oil Question
Hey guys im having a big problem. I just changed the oil on my car. Ive driven the car about 60 miles since the oil change a few months ago. i used Royal Purple and a Fram oil filter. Now i decided to check the oil out of boredom and there is almost no oil in the car. I checked the drain plug and there is no oil around the plug. Im losing my mind here trying to figure out where the fack my oil went. There is a slight leakage around the valve cover gasket, but my car has always had that. The motor hasent ran since about 5 months b4 the oil change. If anyone has any help or info that can help me it would be greatly appreciated. Thanks.
Old Nov 23, 2008 | 01:28 PM
projectTeG's Avatar
are you sure you put enough in the engine?
Old Nov 23, 2008 | 03:59 PM
IM positive. I put another quart in there today drove it around the block. Ripped vtec in 2nd and 3rd. took it back home and a 1/4 of a quart was missing already.
Old Nov 23, 2008 | 04:14 PM
98civdx's Avatar
Master Detailer
drain the oil...
i have had my eks dip stick say there is no oil in the motor then when i drain it its freaking full of oil...
Old Nov 24, 2008 | 06:08 AM
Yes i will be doing an oil change this afternoon and seeing what happens.
Old Nov 24, 2008 | 06:42 AM
joey1320's Avatar
now you said you drove about 60 miles before realizing that the oil you had put in the engine was low... low to the point of not showing on the dipstick. then you add a quart and "RIPPED VTEC in 2nd / 3rd Gear" ???
WTF would you do that... beating the engine after knowing that it had low oil is really f'ing stupid... If i was you i would do a compression test on all 4 cylinders. I had the same thing happen to me and #2 piston rings were gone. I had 130psi on that cylinder as opposed to 230+psi.
Good luck!
Old Nov 24, 2008 | 06:50 AM
White Smoke's Avatar
i my honda
Global Mod
The car takes almost 5 1/2 qt's of oil, just so you know. Also when are you measuring the oil? You should start it and let it warm up then check it a few min after you shut it off. Try switching to another oil, what are you using now?
Old Nov 24, 2008 | 06:52 AM
joey1320's Avatar
Yeah i figured he would have known how to properlly check the oil, thats why i didn't put that on my post... but thanks for the input smoke!
Old Nov 24, 2008 | 11:45 AM
Well im using Royal Purple 10w30. When i added the extra quart the dipstick read almost full. Thats why i decided to run it hard to see whats going on. Im going to go and check it in a few mins and lets hope for the best.
Old Nov 24, 2008 | 12:33 PM
I checked the oil while the car was cold and i got a almost full reading.
Old Nov 24, 2008 | 07:03 PM
dagle's Avatar
REALLY NOW? it didn't occur to you that when you drove the car that there's oil circulating in the motor? you check the oil level after the car's cooled down..
Old Nov 24, 2008 | 08:38 PM
I ran the car today and checked the oil the level was fine. Idk i guess i didnt take into account the oil circulating the engine needed a lil time to fall back to the oil pan lol. I had a noob moment. Mods please lock thread.
mrcoolhead
Feb 6, 2013 02:51 AM
highwhey
Nov 11, 2010 05:53 AM
EGgoJDM
Dec 1, 2009 12:05 PM
TheCrimsonGhost666
Jul 8, 2009 08:21 PM
Kevm30
Honda Civic (2006 - 2015)
16
Nov 17, 2006 11:54 AM
