compression ratio to compression test#
Old Sep 21, 2006 | 05:35 AM
CRXtacy2006's Avatar
Default compression ratio to compression test# UPDATE!
I just did a compression test on my motor last night, because for some reason its drinking my coolant. i'd say in the passt month ive had to top it off 3 times adding about 1/2 gallon each time (more or less) Can't find any visible leaks or puddles under the ground so i checked my compression to see if maybe the head gasket seated wrong. I bought a new gauge from advance, and did the test with the injectors unplugged, and the throttle wide open. I got (right to left 1-4) 272,271,273,269 which isn't but a 4psi difference which from my understanding is ok. I was wondering if anyone had any ideas as to where my coolant is going, and is my compression higher than my calculated 11.6:1 ? Thanks in advance guys.
Modified by CRXtacy2006 at 10:00 PM 9/21/2006
Old Sep 21, 2006 | 05:41 AM
walker111's Avatar
Default Re: compression ratio to compression test# (CRXtacy2006)
Ur compression is amazing! My accord is doing the same thing and I have no clue where the coolants going...
Old Sep 21, 2006 | 05:45 AM
Dave_B's Avatar
Does the exhaust have a sorta sweet smell to it?
Old Sep 21, 2006 | 08:45 AM
RPRacing's Avatar
bring it over ***, we'll do a leakdown test
Old Sep 21, 2006 | 10:24 AM
nope no smell from the exhaust, and i checked the heater core also. It must be magic.
va beach is a little far to drive in all that traffic after work dont ya think? After last time i told myself i wouldnt do it again haha.
Old Sep 21, 2006 | 05:59 PM
update, i ran the crap out of it just now on the way home, kinda like an auto cross on some back raods near my house. keep in mind its like 60 degrees here right now. when i got house it was spewing antifreeze from the overflow tank, and the upper hose was tight as crap. any ideas???
Old Sep 21, 2006 | 09:08 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (CRXtacy2006)
either t-stat is closed shut or headgasket is leaking...was the lower hose hot or cold?
compression test won't tell you if the headgasket is blown, you need to leakdown for that
92vxjdm
Aug 15, 2008 05:05 AM
self_made
Jun 19, 2005 12:36 PM
shadowdawn
Oct 11, 2002 02:07 PM
