Honda S2000 Honda S2000
map sensor replace! still same problem
Old May 29, 2006 | 07:48 PM
S2000Forsale's Avatar
Default map sensor replace! still same problem
i had a low idle issue, so i replace the map sensor ... but i still have the same problem, when car come to a complete start the car just shut off.
what can i do? any advise?
Thank you
Old May 29, 2006 | 07:51 PM
Miracle's Avatar
Default Re: map sensor replace! still same problem (S2000Forsale)
Throttle Pos????
Dirty filters?
Old May 29, 2006 | 09:00 PM
Default Re: map sensor replace! still same problem (Red7thGen_ex)
no dirty filter, i put a brand new filter,
Old May 29, 2006 | 11:11 PM
i2ishift's Avatar
you mean when your car comes to a complete stop? if so it sounds like it could be a faulty idle air control valve
Old May 29, 2006 | 11:27 PM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i2ishift &raquo;</TD></TR><TR><TD CLASS="quote">you mean when your car comes to a complete stop? if so it sounds like it could be a faulty idle air control valve</TD></TR></TABLE>
And we have a winnnaarr!!!
Old May 30, 2006 | 07:02 AM
negcamber's Avatar
Also clean your throttle body. There is a small passage that allows air to get to the MAP. If it gets partially blocked, it can cause problems with idle.
Old May 30, 2006 | 08:32 AM
kane.s2k's Avatar
Default Re: (negcamber)
throttle body cleaner...not carb cleaner
Old May 30, 2006 | 09:55 AM
iam7head's Avatar
Default Re: (kane.s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">throttle body cleaner...not carb cleaner</TD></TR></TABLE>
most carb cleaner you can buy today is carb+throttle body, i guess it's a generic name of the product that people associate with.
are you getting low idle? or stalling? or lumpy weird idle?
1)check the map sensor's rubber seal, it will give you crappy idle if it doesnt sit right
2)dirty manifold, very often case with the S, you have no idea how much the pvc suck in the oil straight to the mani.
3)carbon build up in the cylinder, use honda top engine cleaner, it got rid of my stalling once and for all.
99ek4Dr
10
Mar 2, 2011 06:22 PM
SilverWarrior
21
Mar 14, 2008 07:09 PM
mikeunreal
Oct 26, 2005 05:31 PM
CA6VTEC
Sep 14, 2004 05:57 PM
paul93sir
Feb 5, 2004 11:26 AM
