Is it the MAP Sensor
Old Mar 19, 2014 | 05:22 PM
fancyfruitcup's Avatar
Default Is it the MAP Sensor
all of the symptoms of a bad MAP are consistent with my car's problems. When I tested to see if it was the MAP I unplugged it and the car shut down. Does that mean that the MAP is fine? or is it just shutting down because the car knows there was no MAP sensor plugged in?
Old Mar 19, 2014 | 08:57 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Is it the MAP Sensor
You will need to test the MAP itself. To verify that the MAP is working correctly and is working within voltage spec. Check out this link where phootbag dispenses a bit of knowledge. https://honda-tech.com/forums/honda-accord-1990-2002-2/map-sensor-test-3010261/
Our cars are Speed Density cars, the two main components that calculate air density are the MAP and Air Temp sensor. There is no MAF to do that on these Accords.
journeyquest
Jul 23, 2014 02:58 AM
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
rnbguy
Jan 20, 2008 03:46 PM
Carbcivic
Mar 14, 2007 05:55 AM
zman
Jun 15, 2006 07:40 PM
