Honda S2000 Honda S2000
heat shield
Old Apr 3, 2006 | 03:03 PM
texx's Avatar
Default heat shield
Want to do some heat sheilding. looked at the J's but I dont think it will work (sidewinder manifold 3in. ). I mainly want to shield the passenger side - AC lines, battery, fuse box. Now I would love to have something to look as nice as the J's. But if I have to maybe I could wrap these areas in something. I know someone has tackled this.
Old Apr 3, 2006 | 03:15 PM
WowOzYouRock's Avatar
Default Re: heat shield (texx)
just wrap it with spoon Heat-Shield Tape
Old Apr 3, 2006 | 03:26 PM
texx's Avatar
Default Re: heat shield (Honda-Tech-Jerk)
I may end up doing that very thing. But I was hoping that I could find a nice aluminum one and then buff it out. By the way, its impressive the way you can post and have pictures of what you're referring to that quickly!
Old Apr 3, 2006 | 03:28 PM
Nishant's Avatar
The HT Jerk has no life, what do you expect
Old Apr 3, 2006 | 03:49 PM
actually the aluminum piece still heats up the AC lines ... on thing you could do is wrap the manifold with exhaust wrap ... make the whole engine bay cooler
Old Apr 3, 2006 | 04:31 PM
texx's Avatar
I see the wrap sometimes, never used it though. It appears to be some kind of nylon. I'm not sure. Where can I find it ?
Old Apr 3, 2006 | 07:49 PM
negcamber's Avatar
All kinds of heat management material is available at:
http://www.blrmotorsports.com/suppliesheat.htm
If you just want to protect the AC and heater lines, get the Thermal Hose Sleeving. Or attach a pad of Inferno Shield to the remaining heat shield that protects the AC & battery area.
Careful with wrap on your $$$ header. Many have experienced premature failure of exhaust systems that have used it (including me)...they can crack and fall apart. It would probably be better for header life to send it to Jet-Hot for coating inside and out.
Old Apr 3, 2006 | 10:06 PM
evil vapor's Avatar
Default Re: heat shield (negcamber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negcamber &raquo;</TD></TR><TR><TD CLASS="quote">All kinds of heat management material is available at:
Careful with wrap on your $$$ header. Many have experienced premature failure of exhaust systems that have used it (including me)...they can crack and fall apart. It would probably be better for header life to send it to Jet-Hot for coating inside and out.</TD></TR></TABLE>
to having the headers coated.
To protect the ac lines and heater hoses, run reflective tape with a fiberglass core. Running a hood with some kind of ventilation helps as well.
Old Apr 4, 2006 | 05:08 PM
texx's Avatar
This site makes me wish I had more things to cool. Thanks!
JKov240
Apr 12, 2011 08:23 PM
Sturg
Oct 6, 2009 04:57 PM
Saosinx
Jan 31, 2006 02:12 PM
95TEG
Jun 14, 2002 02:23 PM
project dc2
Jun 4, 2002 10:49 PM
