wrapping AC lines?
Old Jun 4, 2002 | 08:41 AM
project dc2's Avatar
Default wrapping AC lines?
anyone here wrap their AC lines ? with what and where can i get some at home depot/ kragens/autoparts etcc. I dont feel like paying 20-50$ for a roll of thermal wrap when i can prob just get a small piece for waht i need to cover. thanks
Old Jun 4, 2002 | 10:03 AM
Trac226's Avatar
Default Re: wrapping AC lines? (project dc2)
Nah, i just zip tied them away from the exhaust manifold.
Old Jun 4, 2002 | 10:18 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: wrapping AC lines? (Trac226)
I used Thermo-tec's thermo sheild http://www.thermotec.com/tt/shield.html
art
Old Jun 4, 2002 | 10:21 AM
Flamenco-T's Avatar
Default Re: wrapping AC lines? (Arturbo)
mine...costed me $ 9 per foot..., I used it on oil return line as well since my dumptube is in the direct staright path of the oil return lines
Old Jun 4, 2002 | 10:45 AM
inspyral's Avatar
Default Re: wrapping AC lines? (Flamenco-NA)
Old Jun 4, 2002 | 11:06 AM
Aeka GSR's Avatar
New User
that one looks pretty clean
Old Jun 4, 2002 | 11:43 AM
MarsGodofWar's Avatar
Default Re: wrapping AC lines? (inspyral)
nm, i looked at your website.
You don't like the drag manifold, any recomendations for manifolds that allow AC?
Thanks,
David
[Modified by MarsGodofWar, 8:45 PM 6/4/2002]
Old Jun 4, 2002 | 11:49 AM
speshuled619's Avatar
is that orange stuff from earls? also you got any pics of you engine bay or turbo setup i wanna check out how you it looks.
Old Jun 4, 2002 | 12:05 PM
01geeser's Avatar
New User
Default Re: wrapping AC lines? (MarsGodofWar)
Thanks,
David
inlinepro
Old Jun 4, 2002 | 12:28 PM
Default Re: wrapping AC lines? (01geeser)
does inline-pro have a SOHC manifold?
Old Jun 4, 2002 | 06:37 PM
inspyral's Avatar
Thanks,
David
DRAG III manifolds are decent, mine's a DRAG I
Old Jun 4, 2002 | 08:31 PM
dbman96's Avatar
New User
On a similar topic, has anyone damaged their AC lines and repaired them? One of my IC hose clamps rubbed a small hole in my bottom high-pressure side AC line and I'm trying to figure out if I should try to fix it (pull the line, TIG it at work) or start looking for a replacement...
Old Jun 4, 2002 | 10:49 PM
Ri5e's Avatar
Default Re: wrapping AC lines? (dbman96)
MY A/c line blew because I didn't use a dumptube. If its the rubber line, u can get a barbed connector and reconnect it.
if its the aluminum part, u can goto a place that does aluminum welding. OR cut it in half, buy a 1 inch aluminum cylinder that slips over the damaged part and JB/Ghetto weld the ends.
eagleclawracing
Aug 17, 2006 04:15 AM
Saosinx
Jan 31, 2006 02:12 PM
dominate9
Oct 7, 2003 07:03 AM
HmgLauj69
Aug 25, 2003 01:36 PM
