Clicking...
Every time I start moving the car there is a clicking sound that comes from the rear of the car... does anyone have a clue as to what it might be?
Rear axle problem.
Re: (diewX3)
well I just had them inspected, they said that they are fine
Re: (Otherguy)
broken final gears in the diff?
Re: (LAS2K)
I hope not, how can I check
Re: (Otherguy)
Well, I think the axles might be moving around, Im going to re torque them down
Re: (Otherguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy »</TD></TR><TR><TD CLASS="quote">I hope not, how can I check</TD></TR></TABLE>
change your diff fluid...if you get chunks of metal and crap, then its time to open her up. |
Re: (LAS2K)
how much do you think it would cost to repair?
Re: (LAS2K)
clicking:
retroque the nuts to 220ft lb, it doesnt matter if it's new or not. do you drive the car often? if not the rear pad could be sticking. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy »</TD></TR><TR><TD CLASS="quote">how much do you think it would cost to repair?</TD></TR></TABLE> for diff? 1000 ish https://honda-tech.com/forums/images...s/emthdown.gif did it clicks when you are turnning or just clicking whenever moving? |
Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">clicking:
retroque the nuts to 220ft lb, it doesnt matter if it's new or not. do you drive the car often? if not the rear pad could be sticking. for diff? 1000 ish https://honda-tech.com/forums/images...s/emthdown.gif did it clicks when you are turnning or just clicking whenever moving?</TD></TR></TABLE> Im having the same problem, but it only clicks when I turn regardless if Im in gear or not. What do you think it may be? Im hoping I just need to retorque the axle nuts. |
Re: (whitey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitey »</TD></TR><TR><TD CLASS="quote">
Im having the same problem, but it only clicks when I turn regardless if Im in gear or not. What do you think it may be? Im hoping I just need to retorque the axle nuts. </TD></TR></TABLE> Axle nuts. |
Re: Clicking... (Otherguy)
check and make sure the exhaust not hitting something... grab the exhaust tip (when its not hot, of course... if you did, then you are an idiot... https://honda-tech.com/forums/images...s/emsmilep.gif) wiggle it around and observe..
i have the same problem https://honda-tech.com/forums/images/smilies/emsad.gif
