Honda S2000 Honda S2000
Check Engine light
Old Jun 23, 2005 | 07:11 PM
OriginalFive's Avatar
Default Check Engine light
as i was driving home, my "check engine" light came on. I really didnt kick it, though to 7500rpm on third and threw it around the off ramp. I read the owners manual and it says its either the emissions control or gas cap, but i havent filled my car yet and its running with only 2bars of gas left.
any of you guys have this problem? if i scanned the computer and found what the problem is and cleared it, would that help, or do you guys recommend taking it to the dealer to check it out? im guessing they would also scan to see what the problem is right?
help! i dont feel like driving the car, but i need to drive it...
thanks for viewing and replying!
Old Jun 23, 2005 | 07:25 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: Check Engine light (OriginalFive)
scan it and get the code or what the problem is to see how serious it is....thats what the dealership will do....
Old Jun 23, 2005 | 07:26 PM
Default Re: Check Engine light (TeGmAn18)
oh n dont clear it unless it is nothing becuase th problem wont just go away
Old Jun 23, 2005 | 08:58 PM
Ok, i found out what the problem is. I scanned it and it said the problem is the "O2 sensor heater circuit malfunction. Bank 1 sensor 2"
where is that located? is it busted, or loose?
Old Jun 23, 2005 | 09:12 PM
onepointeightTURBOdub's Avatar
sensor 2 is the sensor behind the cat if its a heater circuit malfuntion then you best just buying a new one
Old Jun 23, 2005 | 09:48 PM
Default Re: (onepointeightTURBOdub)
thanks for the info!
Im gonna get the car checked after im done work today, so hopefully ill find the problem is fix it. Thanks
Old Jun 23, 2005 | 10:00 PM
revhi's Avatar
What years your car, how many miles and did you by it from Honda?
If its that sensor theres a good chance that the cat went bad to. Same thing happened to my g/f's S. First cel, never replaced the sensor and eventually the cat went bad and started making noise.
Cats have 7-75 factory warrenty and hers was replaced under it including the sensor.
Old Jun 24, 2005 | 06:32 AM
a heater circiut failure does not indicate a bad cat the heater is just used to heat up the o2 to operating temperature
Old Jun 24, 2005 | 12:43 PM
i cleared the code and it came back on, so im sure its a fried sensor. Im awaiting a new one from dealer, but wont come in til tuesday. Is it ok to drive the car the way it is, or do you not recommend not driving it? i wouldnt think it'd be a problem driving it, just as long as i dont drive it hard.
Old Jun 24, 2005 | 12:57 PM
By the way. How would the O2 heater sensor look like. Is it bolted into the cat and wires connecting somewhere else?
Old Jun 24, 2005 | 10:01 PM
someone else's Avatar
It Wasn't Me!
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">What years your car, how many miles and did you by it from Honda?
Cats have 7-75 factory warrenty and hers was replaced under it including the sensor.</TD></TR></TABLE>
Heater failure has nothing to do with a bad cat. And the Cat warranty is 8yrs or 80K miles not 7-75.
The O2 sensor sticks out of the cat and has wires coming out of it. And you are fine to drive the car until you repair the sensor.
Old Jun 24, 2005 | 11:00 PM
revhi's Avatar
The falorue of the heater or sensor could be due to the cat breaking apart inside and damaging the sensor as what happened to my g/f's S. I thought Honda told me it was 7-75, not positive.
Old Jun 24, 2005 | 11:50 PM
It Wasn't Me!
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">The falorue of the heater or sensor could be due to the cat breaking apart inside and damaging the sensor as what happened to my g/f's S. I thought Honda told me it was 7-75, not positive.</TD></TR></TABLE>
It's 8-80, I work for Honda.
From your previous post it sounds like the sensor failed before the cat if the light was already on. A bad secondary o2 ignored for long enough can cause a cat failure.
Also, cat pailure throws a P0420 code which is different than the codes for a o2
Old Jun 25, 2005 | 09:41 AM
Default Re: (hondasean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasean &raquo;</TD></TR><TR><TD CLASS="quote">
Also, cat pailure throws a P0420 code which is different than the codes for a o2</TD></TR></TABLE>
Old Jun 26, 2005 | 01:27 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasean &raquo;</TD></TR><TR><TD CLASS="quote"> A bad secondary o2 ignored for long enough can cause a cat failure.
I dont see how a bad secondary o2 sensor could cause a cat to fail. How could it?
Old Jun 26, 2005 | 01:36 PM
revhi's Avatar
Other way around, the bad cat can cause the sensor to fail.
Old Jun 27, 2005 | 05:23 AM
s2kkid's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
I dont see how a bad secondary o2 sensor could cause a cat to fail. How could it?</TD></TR></TABLE>
It cant.
A Primary can, not a secondary.
Remember guys, all the secondary does is monitors the efficiency of the cat. Basically If its doing its job correctly.
The primary, Reads Raw exhaust gas. say it was giving improper readings and tricking the ecu into dumping a little more fuel.
The raw fuel, aka rich A/F mixture, can inturn ruin the catalytic converter.
Old Jun 27, 2005 | 05:28 AM
Chiovnidca's Avatar
Default Re: (vtecluder97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 &raquo;</TD></TR><TR><TD CLASS="quote">
The primary, Reads Raw exhaust gas. </TD></TR></TABLE>
You mean it reads how much oxygen is in the exhaust gas, right?
Old Jul 18, 2005 | 12:34 PM
jdmsoljah's Avatar
so is that happening for my car
94 del sol s
95 gsr motor
00BoostedGSR
Sep 24, 2007 06:28 PM
Depeche
Jul 16, 2007 11:59 PM
civicpower94
Jul 30, 2005 08:40 PM
Vega
Mar 7, 2005 07:32 AM
gmsu00
Oct 14, 2001 10:41 PM
