Can S2000 be converted to OBD-1
Friend of mine got a call from a guy he works with... The guy wants to know if you can do a OBD-1 conversion to his S2000. I dont know a whole lot about anything 2001 and newer, but arent RSX's and S2000 OBD-2. Is it possible to run a chipped OBD-1 B series ECU to these cars?
Re: Can S2000 be converted to OBD-1 (S2quick4U)
whats the point of converting to OBD-1?
yea for reals
yea for reals
Re: Can S2000 be converted to OBD-1 (underrated99si)
Yes, he was looking into doing a chipped ECU. A buddy of mine has been experiementing with homemade chips.
All I really need to know is can an S2000 be converted to OBD-1??
Re: Can S2000 be converted to OBD-1 (23psi4age)
There isn't one.
Just buy a stand alone ODBII Fuel Management system if you want to play with the ignition and fuel maps. Chipping this car is worthless and it would be a massively huge hassle to shred up all of the wiring.
Re: Can S2000 be converted to OBD-1 (zc911)
You cannot convert it to obd-1 because it doesnt run the traditional distributor. The S2000 are distributorless and run coilpacks built into the sparkplug wires. I will be offering the ecu upgrade for Hondata when they come out with it soon...
Re: Can S2000 be converted to OBD-1 (prospeed)
Thank you for a straight answer....
Keep in touch about your ECU prog coming. Ill let the guy know...
