Burned COIL ON S2K
Burned COIL ON S2K
Hello guy's.
Is anybody have any idea where i can buy this application like the pic below and what is the parts# that i need to ask for?
Is somebody can help me to install accel coil like pic's below?
Do i need to buy also CDI or that i can Use it on my stock ignition system just to change the wires and the coils?
Do you have diagram?
Thank you
Udi
Thank you
Udi
Re: Burned COIL ON S2K (03s2kblue)
Because I'm running 22 psi and the coils burns like toasts..... they can't stand ... that guy has the same problem: http://forum.aempower.com/bbs/...s2000
With 10psi no problem...
Udi
Udi
Re: Burned COIL ON S2K (u_tal)
That car belongs to Chris. Check out http://www.Chrisdrivesafastcar.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u_tal »</TD></TR><TR><TD CLASS="quote">Because I'm running 22 psi and the coils burns like toasts..... they can't stand ... that guy has the same problem: http://forum.aempower.com/bbs/...s2000
Udi</TD></TR></TABLE>
well in that case. i think you'll get more hits from http://www.s2ki.com ... more people on there will probably know this guy or know his current setup... as far as i know i think the ended up selling his whole setup or heard something around that...
No, you can't use the stock ignition with a setup like that. That particular one uses the AEM C2DI capacitive ignition. I run a similar setup, but I'm using motorcycle coils. You can learn all you need to know about it here:
http://www.s2ki.com/forums/ind...coils
