Honda S2000 Honda S2000
ap1 vs ap2
Old Mar 11, 2007 | 07:45 PM
TheDancingPill's Avatar
Default ap1 vs ap2
i am going to get a s2k soon so i need to know the difference is...any information is greatly appreciated...i want to know which one is worth buying...thanx
Old Mar 11, 2007 | 07:51 PM
LAS2K's Avatar
Default Re: ap1 vs ap2 (TheDancingPill)
Search Results
Your search for ap1 v ap2 returned 32 results.
the search button is red.
Old Mar 11, 2007 | 08:16 PM
james_ls's Avatar
No it didn't.
It gave me 4.
Anyways...I was just asking the dealership the same thing.
Minor under-body layouts (I believe exhaust goes under//over something differently) as well as front end and rear end.
2.0 vs 2.2!!
Old Mar 11, 2007 | 08:36 PM
LAS2K's Avatar
Default Re: (james_ls)
https://honda-tech.com/zerothread?id=1283232
https://honda-tech.com/zerothread?id=1342107
https://honda-tech.com/zerothread?id=1751975
https://honda-tech.com/zerothread?id=1777766
https://honda-tech.com/zerothread?id=1477031
https://honda-tech.com/zerothread?id=1217072
https://honda-tech.com/zerothread?id=1145356
https://honda-tech.com/zerothread?id=1121330
https://honda-tech.com/zerothread?id=1046873
https://honda-tech.com/zerothread?id=725192
https://honda-tech.com/zerothread?id=679343
is this enough?
Old Mar 12, 2007 | 04:49 AM
cmdr430's Avatar
http://www.hondanews.com/categories/898
http://www.hondanews.com/categ...=2001
http://www.hondanews.com/categ...=2002
http://www.hondanews.com/categ...=2004
Old Mar 12, 2007 | 07:52 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ap1 vs ap2 (cmdr430)
consumer report?
car and driver?
Old Mar 12, 2007 | 08:01 AM
HYPEBEAST!'s Avatar
wow we get this like once a week...someone should just make a sticky of links
Old Mar 12, 2007 | 09:05 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (HYPEBEAST!)
IBFTL
btw...
AP1 OWNZ
Old Mar 12, 2007 | 09:21 AM
18psi sohc's Avatar
Default Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">IBFTL
btw...
AP1 OWNZ </TD></TR></TABLE>
The right combo of ap1 and ap2 parts owns Like some custom rod/stroke ratios usin an ap2 block with an ap1 crank. 11k rpms anyone ? I wish i had unlimited $$. Lol
Old Mar 12, 2007 | 04:02 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (18psi sohc)
Who needs 11k rpm? I can get the joob done with less....... But ill take a k24 crank!
Old Mar 12, 2007 | 04:12 PM
S2SLOW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">Who needs 11k rpm? I can get the joob done with less....... But ill take a k24 crank! </TD></TR></TABLE>
Old Mar 12, 2007 | 04:57 PM
LAS2K's Avatar
sigg'ed it.
Old Mar 12, 2007 | 05:12 PM
18psi sohc's Avatar
Default Re: (S2SLOW)
there is a replacement for displacement.. RPM .. but yea k24+f20=
Old Mar 12, 2007 | 05:15 PM
MitsukillinS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18psi sohc &raquo;</TD></TR><TR><TD CLASS="quote">The right combo of ap1 and ap2 parts owns Like some custom rod/stroke ratios usin an ap2 block with an ap1 crank. 11k rpms anyone ? I wish i had unlimited $$. Lol</TD></TR></TABLE>
wish i had unlimited money too
Old Mar 12, 2007 | 09:11 PM
sorry for not searching before posting this topic....my bad
Old Mar 12, 2007 | 09:16 PM
LAS2K's Avatar
Default Re: (TheDancingPill)
haha no worries just make sure to do a quickie search before you ask most questions cause, chances are, its been covered.
Old Mar 13, 2007 | 06:53 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18psi sohc &raquo;</TD></TR><TR><TD CLASS="quote">there is a replacement for displacement.. RPM .. </TD></TR></TABLE>
NEGETIVE!
Old Mar 14, 2007 | 09:34 AM
18psi sohc's Avatar
no ? lets do some math..
an f24c would flow about 5,430 cfms at 8grand,
an f20c would flow about 6,100 cfms at 10.5grand.
It's top end hp but with the right cams and gears the power band could be just as usable. People already rev there f22c to 9 grand and i've seen ppl rev the f20 to 10. So if you were to take an f22c block and put an f20 crank in it with custom longer rods the rod/stroke ratio would be good for probably at least 11k rpms. Finding the cam to make use of all that rpm would be a mission tho..
Old Mar 14, 2007 | 09:39 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
honestly, who the hell needs all that rpm other then F1 guys? no one here i would say 9K is more then enough for "US" street/road/drag guys.
i see your point totally, but let be real here displacment gets the job done. torque is what moves the masses....
Old Mar 14, 2007 | 09:40 AM
Mr. Projekt's Avatar
* B A N N E D *
If you're gonna use custom rods, why not just use custom cams too? F22@9k, been there, done that.
Old Mar 14, 2007 | 09:42 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Mr. Projekt)
K24 crank H22 pistons/rods... im game if i build the S for NA.
Old Mar 14, 2007 | 10:46 AM
18psi sohc's Avatar
It sounds like a great idea but also has the drawback of increased cylinder wear.. I don't kno if the H22 pistons would be a good idea tho. This guy built one who posted on s2ki and said that the valve reliefs on the H pistons look like they'd need work. http://www.s2ki.com/forums/ind...49168 . He used custom frm pistons and rods.
Custom rods would be the only way to go if I was to build a high rpm engine.. I think that's the only way to go if you build the stroker too tho.
Old Mar 14, 2007 | 10:50 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
that was in referance to the budget build, yes i would go aftermarket rods/pistons as well but i would still use the k24 crank
Old Mar 14, 2007 | 10:54 AM
18psi sohc's Avatar
whoops.. i meant to say custom cams... I'd use the k24 crank too if i was to go that route too. Honda's are such giving cars ....
Old Mar 14, 2007 | 11:08 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
with custom cams you will have to do a lot of R&D yourself with specs since their isnt much out there for the F20/22's. or just sit back and see what works out later down the road.
Bisimoto engineering will be in development for F20/22 engine parts for the pwer freak in mind, But it will be sometime before this is done.
