Honda S2000 Honda S2000
ap1 vs ap2
Old Mar 14, 2007 | 03:48 PM
  #26
S2SLOW's Avatar
Default Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">honestly, who the hell needs all that rpm other then F1 guys? no one here i would say 9K is more then enough for "US" street/road/drag guys.
i see your point totally, but let be real here displacment gets the job done. torque is what moves the masses....</TD></TR></TABLE>
Torque gets you moving but Horsepower keeps you moving......
Old Mar 14, 2007 | 04:26 PM
  #27
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (S2SLOW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW &raquo;</TD></TR><TR><TD CLASS="quote">
Torque gets you moving but Horsepower keeps you moving...... </TD></TR></TABLE>
that would be a perfect comment if all roads had no stops and were all str8... hahahahhahah
Old Mar 14, 2007 | 09:34 PM
  #28
TheDancingPill's Avatar
lol...wow
Old Mar 16, 2007 | 02:42 PM
  #29
madjdmy0's Avatar
Default Re: (18psi sohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18psi sohc &raquo;</TD></TR><TR><TD CLASS="quote">there is a replacement for displacement.. RPM .. but yea k24+f20= </TD></TR></TABLE>
you are not very smart.
with rising Rpm Hp will almost consistantly rise but there is a time where the R/S ratio will start efecting how efficient over reving like that really is, in the end you are just prematurely destroying your motor
Old Mar 19, 2007 | 02:03 PM
  #30
18psi sohc's Avatar
Default Re: (madjdmy0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madjdmy0 &raquo;</TD></TR><TR><TD CLASS="quote">
with rising Rpm Hp will almost consistantly rise but there is a time where the R/S ratio will start efecting how efficient over reving like that really is, in the end you are just prematurely destroying your motor </TD></TR></TABLE>
That's a pretty pessimistic way to look at it.. Regardless you're are prematurely destroying your motor genius! If you go k24 or if you go high rpm 2.0. The reason that you get a 3.5 litre increase by stroking an engine is because you're adding speed to the pistons. You think an engine with a 99mm stroke is going to have similar piston speeds as an engine with an 84.5mm stroke in a similar rpm range? Definately not. So either way you're wearing your cylinder walls faster than you would stock. Now do you want more low end efficiency or more low end torque?
Modified by 18psi sohc at 5:17 PM 3/19/2007
Old Mar 19, 2007 | 02:13 PM
  #31
WowOzYouRock's Avatar
its genius NOT genious
Old Mar 19, 2007 | 04:17 PM
  #32
18psi sohc's Avatar
Default Re: (FR-MOB: Jerk)
Old Mar 19, 2007 | 04:21 PM
  #33
you shoulda change "Definately" while you were at it!!
Old Mar 26, 2007 | 10:34 AM
  #34
papa5murf's Avatar
Old Mar 26, 2007 | 11:02 AM
  #35
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
hahahhahah
Old Mar 26, 2007 | 11:07 AM
  #36
Mr. Projekt's Avatar
* B A N N E D *
Hahhahahaha I'd be stirring up some guts regardless if it's 8 or 9.
Stirring guts, rearranging internal organs, ironing out the wrinkles... damn I'm bored.
Old Mar 26, 2007 | 02:09 PM
  #37
fish22's Avatar
oh god, this battle will ever end....
Old Mar 26, 2007 | 09:02 PM
  #38
361 accord's Avatar
Default Re: (fish22)
9&gt;8&gt;6.25
damn i want a S2000
Old Mar 28, 2007 | 10:09 AM
  #39
Aludew5's Avatar
Default Re: (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1283232
https://honda-tech.com/zerothread?id=1342107
https://honda-tech.com/zerothread?id=1751975
https://honda-tech.com/zerothread?id=1777766
https://honda-tech.com/zerothread?id=1477031
https://honda-tech.com/zerothread?id=1217072
https://honda-tech.com/zerothread?id=1145356
https://honda-tech.com/zerothread?id=1121330
https://honda-tech.com/zerothread?id=1046873
https://honda-tech.com/zerothread?id=725192
https://honda-tech.com/zerothread?id=679343
is this enough?</TD></TR></TABLE>
it does suck that newbs don't search...however, did you read any of the threads you found? this was my favorite:
https://honda-tech.com/zerothread?id...ead?id=1751975
WTF?! This question of dif. in s2k's has been asked a lot- but answered little.
Old Mar 28, 2007 | 01:05 PM
  #40
LAS2K's Avatar
Default Re: (Aludew5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aludew5 &raquo;</TD></TR><TR><TD CLASS="quote">
WTF?! This question of dif. in s2k's has been asked a lot- but answered little. </TD></TR></TABLE>
lol you're kidding right?
CivicEK321
Apr 25, 2008 07:17 AM
3tc fooooo
May 10, 2007 01:58 PM
tom91ita
Welding / Fabrication
Jun 14, 2006 09:23 PM
Top Ramen
Oct 25, 2003 08:49 PM
