Honda S2000 Honda S2000
01 S2000 Replacing clutch..., trying to separate transmission & motor
Old 04-14-2010, 01:06 PM
K20_si's Avatar
Default 01 S2000 Replacing clutch..., trying to separate transmission & motor
I've lowered the subframe, removed all the bolts, disconnected all the sensors, and the stupid transmission wont come loose from the engine. I've got it separated about a half inch and it wont budge past that. I've tried 2 pry bars at the same time, on the left and right side and in the little notch at the bottom. I also have a friend helping. I double checked clearance and I can put my hand between the firewall and the trans so it will come off once I break the spline loose.
any suggestions??
thanks for your time
Old 04-21-2010, 12:57 PM
tech7427's Avatar
Default Re: 01 S2000 Replacing clutch..., trying to separate transmission & motor
did you remove the 14mm starter bolt...? you swing the alternator to the side with a long extension and a swivel 14mm, upper starter bolt..kinda pita..
Old 04-21-2010, 04:35 PM
CE-CE's Avatar
did you pull the clutch fork out.
Old 04-21-2010, 05:12 PM
bky
bky's Avatar
just below the bar code in the picture is a slot in the housing. It's for a pry-bar.
Old 04-21-2010, 07:00 PM
Conechaser's Avatar
This is most likely the case, i had the same problem when I pulled my transmission. Push the tranny back up to the motor pull out the fork and the tranny will fall right out.
Old 04-22-2010, 04:28 AM
90Rexx's Avatar
clutch forkkkkkk....
Old 04-27-2010, 07:27 AM
goldsS2000's Avatar
Damned clutch fork. I had the same issue lol
Old 04-27-2010, 07:54 AM
DumpedSi's Avatar
deff the clutch fork. I spent like 30 minutes trying to pull mine apart before researching it on S2ki
paulagriess
06-19-2017 09:51 PM
kfoster1234
Honda S2000
02-15-2017 06:01 PM
integramic
Honda S2000
11
08-29-2005 03:29 PM
89crx23
05-23-2005 05:47 PM
whitericelova
Honda S2000
11-14-2004 01:14 PM
Quick Reply: 01 S2000 Replacing clutch..., trying to separate transmission & motor
