Honda S2000 Honda S2000
my first problem with the s2k.....
Old Apr 22, 2010 | 02:04 AM
JDMxNguyeN's Avatar
Default my first problem with the s2k.....
so today i hopped into my car and thoguht..... wow... my clutch is so short.... must be going out..... i try to throw it in reverse... wont go in..... dammmmmm!!!!!!!! clutch is out......
my car is all OEM.... should i keep it all OEM or wat kinda set up would be best?..... and im also not trying to go broke either.....
thanks
Old Apr 22, 2010 | 02:26 AM
azngotmilk's Avatar
Default Re: my first problem with the s2k.....
if your car is stock, and you dont plan any major engine modifications, then you should stick with a stock set up since it might be the cheapest
Old Apr 22, 2010 | 02:32 AM
JDMxNguyeN's Avatar
but i drive my stock pretty hard.... very hard actually.... want something that will last....
Old Apr 22, 2010 | 03:11 AM
LaTe ApEx's Avatar
Check the level of your clutch fluid.
Old Apr 22, 2010 | 04:26 AM
90Rexx's Avatar
def do this! dont condemn your clutch just yet! slave cylinders leak sometimes, you might need one of those suckers
Old Apr 22, 2010 | 06:34 AM
Papolito's Avatar
I had the same issue when i first bought mine (used), it had air in the line. had my tech bleed the line and 20k later its still going strong
Old Apr 22, 2010 | 06:44 AM
White Smoke's Avatar
i my honda
Global Mod
It's probably your clutch master cylinder, it could be leaking. Check the fluid level. If it's low look for fluid under it in the bay AND inside the cabin. It's not that un-common on the S2000. If that is not check out the slave, then try bleeding.
Old Apr 22, 2010 | 06:52 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
^^^yup
Old Apr 22, 2010 | 07:01 AM
sixsixsix's Avatar
OneWayHighway
You drive your car hard? You cant drive your car. Granny shiftin’, not double clutchin’ like you should. You’re lucky that hundred shot of NOS didn’t blow the welds on your intake.
Old Apr 22, 2010 | 08:58 AM
EJAYATE's Avatar
I Deliver
Borrowed my friends 240 once and this happened to me. It was like 450 whp and i was beating it. Then the clutched stopped working, I added some fliud and it was all good!
Old Apr 22, 2010 | 12:12 PM
S2K-APWON's Avatar
I agree, i was going to spend $800 for a new clutch and labor then my friend looked at the fluids and all i had was a leak in the master cylinder, or was it the slave cylinder? Anyways make sure you check those before going for the full clutch job, saved me hundreds.
JDMxNguyeN's Avatar
ok thanks guys imma have a look at it right now... will get back to u guys....
Old Apr 22, 2010 | 01:46 PM
JDMxNguyeN's Avatar
my fluids are all good.... time to try to bleed the clutch.... WISH ME LUCK GUYSS!!
Old Apr 23, 2010 | 06:13 AM
i my honda
Global Mod
This is your clutch master cylinder, just wanna make sure you are in the right spot. (obviously not the blue FMU)
Here is where you bleed from.
Old Apr 25, 2010 | 02:33 AM
conker's Avatar
If it comes to this, after the fluid check, I agree. I can get the OEM setup to slip on a hard 1-2 shift if I really try, but it borders on abusive technique. I doubt I am any quicker for it and it is not a problem often enough justify an upgrade to the PP. The stock setup is pretty good, not perfect, but pretty damn good.
Old Apr 28, 2010 | 01:43 PM
JDMxNguyeN's Avatar
ok guys thanks for the input... i decided to flush my system and it seems to be ok..... ahaha lets see how long it last...... thanks
Si93_22
Oct 29, 2007 08:59 AM
mike5809
Mar 4, 2007 07:10 AM
kazman
Feb 2, 2007 12:28 PM
