*** got a problem can any help ***
New User
I woke up this morning and my car started to boggle and then die instantly. At first i was like maybe the cold weather but then at the stop light it died again at the moment i was concerned. Then after that it was like at every single stop i made it would die on me very strange cause i had just bought this car two month ago. Has anyone experience the same thing? Please help me or else its the dealer for me and that means a lot of $$money$$ i thought honda's were good cars but not the one i have now! HELP ME PLEASE
Re: *** got a problem can any help *** (blacks2000)
did you buy the car used? If so, check to see if its had the spark plug update done. If not it may be so bad its causing the car to die.
New User
Re: *** got a problem can any help *** (SleeperEG6)
new spark plugs where install ( denso part#:ik22) ... still happens .. while going on the road the minute i stop ... a stop sign or stop the car to park the car dies on me seems like the throttle response isnt high enough so i try adjusting the throttle cable it now idle at 100orpm when the car is warm ... it worked for a while now it happens again? could it be a sensor? i had a check engine on but after resetting the ECU it went away...
it may be clogged injector(s). i used Wynn's injector cleaner to take care of it. This stuff is good, you actually attach the bottle so that the cleaner gets sucked into the intake manifold. havent had a any problems since.
NAEK HATCH
07-23-2011 09:16 PM
