When should I shift?
Old Jul 8, 2002 | 03:39 PM
proton's Avatar
Default When should I shift?
Currently, I'm shifting at about 8100rpm in every gear. When I shift to second I get quite a bit of wheel spin. I'm wondering I could get better times if I shifted earlier from 1st to 2nd to avoid the spinnng. I'm gonna try this next time I'm at the track but I'm so inconsistent that I don't know if it would even tell me anything. Thanks.
Old Jul 8, 2002 | 04:02 PM
HXMan's Avatar
Default Re: When should I shift? (proton)
You want to shift at redline. Try not shifting so hard.
Old Jul 8, 2002 | 11:35 PM
JMF's Avatar
JMF
With high revving cars like these, it's a pretty safe bet to shift at or as near to fuel cutoff as possible. I shift at 8200-8300 (indicated) and I do get the wheelspin in second gear that you are talking about, but the only quick fix for that is to slip the clutch into second instead of dumping. But even if you could do that perfectly and totally avoid wheelspin, you would probably only knock a couple hundredths off your ET, and the chances of you messing up are even greater.
Old Jul 9, 2002 | 02:59 PM
ITR21's Avatar
Default Re: When should I shift? (JMF)
i shift past redline but right before my fuel cut. on my car its 8 700
lude98SH
Jun 15, 2008 09:40 PM
Retselover
Honda S2000
18
Oct 3, 2003 02:15 PM
b20civic
Apr 14, 2003 12:43 PM
Juantay19
Apr 2, 2002 10:43 AM
