Vtec Doesnt work sometimes......help me
Everyday when I first start my car and I let it warm up. When I get goin I gas it waiting for my vtec to kick in and nothing happens.. So what I have to do is pull over and shut the car off and and turn it right back on and vtec works like nothing ever happened....whats wrong? can anybody help??
Guest
Posts: n/a
VTEC does not engage for the following reason
wiring problem
lack of oil presure
or if car hasn't reach operating temp
if it was a wiring problem, you'd get CEL, and if you say you can turn the car off, and then when you start it later, it will work, the MOST LIKELY you are not letting the engine reach it's operating temp. before expecting the VTEC to engage
wiring problem
lack of oil presure
yea i already thought about all those..but the one thing that is getting me is that i am at proper temp and it still doesnt work...so i am thinking its the wiring....BUT what would make a wire or wires get power just by shuting the car off and back on?? Another thing i thought of is a bad vtec solenoid or something with the oil pump, pressure switch. God, my ex mechcanic is awful..i wish i knew how to work on my own stuff with out breaking s**T
Check to see if your oil pan is dented. Same thing happened to me. I had a dent that was slowing my iol pressure down. I took it off and pounded it out with a rubber mallet. It works perfect now.
There are 2 strainers which filter oil for VTEC. They love to be full of different **** and block oil flow. I changed mine for a couple bucks.
pentaq
pentaq
Hmmm...where are these filters at????? I know of a filter behind the vtec solenoid. Thanks for the help.
Oh dont think my oil pan is dented...But i will check anyway. Who knows.... it hangs very low and i bash my header all the time so its possible.
[Modified by 3gLudeH22A, 3:20 PM 11/21/2002]
Parts number 16 and 18. 16 had some dirt caught. 18 less but still had.
pentaq
p.s first time tried to insert pic. hope it works
cool, 16 is the vtec solenoid valve filter..and 18 i dont know...but ive got a helms manual so i can find out quick...thanks for the help.
