tps testing?
Old Sep 25, 2002 | 11:44 PM
self_made's Avatar
Default tps testing?
so Im having the sputtering problem, I wanted to check the tps, but Im somewhat of an electrical moron, can someone tell me at what to set the multimeter to check it, and what plugs do I plug in the probes? heres a 'pic' of the multimeter I will be using..thanks
Old Sep 25, 2002 | 11:58 PM
4bidden's Avatar
Default Re: tps testing? (VTECNLUDE)
explain your hesitation
Old Sep 26, 2002 | 12:09 AM
self_made's Avatar
Default Re: tps testing? (4bidden)
same, like above 4000RPM, around there, it runs perfect, below that, if I get on the gas anymore than like 1/4, it'll start sputtering, and feels like theres no power but when it passes about 4000, its perfect
Old Sep 26, 2002 | 05:27 AM
CaNaBiS's Avatar
I had similar problem. Car had 6 month old Beck Arnley cap and rotor and brand new Denso plugs.
I started down the same path as you.
Solution: Threw away cap and rotor and got HONDA cap and rotor and NGK PFR6G-11 plugs.
Runs perfect ever since.
Old Sep 26, 2002 | 05:25 PM
92TypeR's Avatar
FSAE
Default Re: tps testing? (CaNaBiS)
I just checked mine minutes ago (having idle problem).
The symbol on the meter I measured with looks like this:
V... and there is a line above the 3 dots.
Anyways, i put a small paperclip in the middle pin, and attached the ground cord thingy to a ground bolt, and bent the paperclip so that the other cord thingy can sit in it without my hands on it. I then had my hands free to hold the ground, and pull the throttle.
Good luck.
zanglezonker
Dec 9, 2008 04:17 AM
jdsmooth
Mar 7, 2008 04:59 PM
JDM_SOHC
26
Jun 28, 2006 11:55 AM
Touge Tuning
Jun 27, 2005 06:42 AM
SiR Inspired ED7
May 20, 2005 02:42 PM
