tps adjustment help
With the key on but the engine off you measure voltage between the RED/WHT wire and body ground, with the throttle closed, bolts for the tps loose, rotate the sensor until it reads 0.5V with the throttle closed. Tighten the screws on the sensor and open the throttle all the way and at WOT it should read at 4.5V, if it's a few millivolts off don't worry. You're gonna need a digital multimeter and a back probe kit to probe the backside of the connector on the sensor.
I've changed my tps an adjusted it right an my car is still not taking gas it has to do with the Tom's because they go up an down when they go up I get gas when they go down it stops getting gas this is on a 94 Honda prelude
si del sol 94
18
Sep 16, 2009 07:39 PM
