tps sensor closed 0v wot .47v help
Old Mar 16, 2016 | 10:28 PM
dangerous_d's Avatar
Default tps sensor closed 0v wot .47v help
ok so like title says I'm having tps issues I've checked voltage and i have 5v and i checked ground and its okay i bought 2 different tps sensors and got similar results any ideas to fix would be helpful
Old Mar 17, 2016 | 04:14 AM
motoxxxman's Avatar
Default Re: tps sensor closed 0v wot .47v help
the sensor is installed wrong. the TB has two tabs, and the tps has 1 tab. the sensor tab has to go in between the TB tabs. to do this, you need to set it on rotated too far clockwise to align everything, then once pushed in rotate it counterclockwise to line up the screw holes and put the screws in slightly less than fully tight to allow for easy loosening for proper adjustment
Old Mar 18, 2016 | 08:51 PM
i did that now it reads anywhere from 30-50mV to about .5V
Old Mar 18, 2016 | 09:50 PM
2kdrift's Avatar
sounds like u need to adjust it with the bolts loose like motoxxxman said, if you cant get it to .45V it could be defective and you need a new one
Old Mar 19, 2016 | 05:33 PM
motoxxxman's Avatar
if the sensor tab is indeed between the two TB tabs and you're getting those readings, you have quite a bad sensor
Old Mar 23, 2016 | 08:30 AM
DarryCar's Avatar
Have you fixed your problem yet? I guess my first question would be what was the problem that made you look at the TPS to begin with? Where you having throttle issues? Did you replace the TB? What I am leading to is, could this be a throttle cable adjustment issue? Are you sure the TB plate is fully closed and fully open? Are you checking voltage while using the gas pedal, or by manually opening the throttle plate without using the cable? These little things can make a difference. My question is, why did you start messing with the TPS in the first place?
408h22a1
Feb 27, 2013 07:41 PM
cryingsuns
Mar 20, 2011 01:13 PM
kornerk12
Jun 15, 2007 04:01 AM
EFRue57
Sep 17, 2005 05:41 PM
ActiveAero
Aug 15, 2003 07:40 PM
