What is a TPS?
Old Sep 16, 2002 | 09:24 AM
skyline69's Avatar
New User
From: Craigavon, Co. Armagh, Northern Ireland, Northern Ireland
Default What is a TPS?
My car has been having the same sluggish problem and I noticed the TPS post but don't know what you mean by TPS - could someone deciper the TLA of TPS please.
Brian
[Modified by skyline69, 6:24 PM 9/16/2002]
Old Sep 16, 2002 | 09:27 AM
n1ek's Avatar
Default Re: What is a TPS? (skyline69)
tps is a throttle position sensor, it's located on the throttle body and it pretty much senses throttle postion.
Old Sep 16, 2002 | 09:39 AM
skyline69's Avatar
New User
Default Re: What is a TPS? (n1ek)
Thanks, does it gone wrong on 4th Gen Prelude (VTEC) a lot then as for the last 4 months I have been driven crazy with my Lude sometimes refusing to behave correctly e.g. when it gets warmed up it may sometimes be very sluggish to accelerate - like it was under heavy load (you can heard the strain in the exhaust). I have removed the cat, had the dizzy checked, plugs and leads replaced and I'm currently going to get the Fuel Pressure sensor replaced - anyone have similar problems?
Old Sep 16, 2002 | 09:50 AM
n1ek's Avatar
you can remove it and test it.
or take it to a shop. it sounds like it may be the problem. or some fuel/ignition.
check the tps though
Old Sep 16, 2002 | 10:44 AM
DirtyLude's Avatar
It's unlikely that it's the TPS sensor. If it totaly failed it would throw a code. It's not used to determine fueling requirements and has no relation to a/f ratio. It simply senses when the car is at zero throttle and needs to fuel cut or use it's idle controls and it's used to tell whether the car should be pulled out of closed loop mode.
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
geogal84
Oct 23, 2007 02:41 PM
Team ICU
May 2, 2007 11:14 PM
nutball72
Nov 11, 2006 07:14 PM
Boost3d22
Mar 17, 2005 12:48 PM
