Timing question...
Old 12-28-2008, 10:01 AM
EX-T's Avatar
Default Timing question...
My cam timing is off a few teeth and I have an adjustable cam gear. The timing marks that can be seen with a timing light are toward the front of the car from the notches in the timing cover. Which way do I need to rotate my cam gear to compensate for this, towards the front or towards the rear? My distributor is also all the way towards the front of the car.
I have another question...
How do I know if the crank is at TDC?
Old 12-28-2008, 10:04 AM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: Timing question...
if your initial timing is off, there is no way to CORRECTLY fix it without removing the belt and indexing the initial timing that way.
Old 12-28-2008, 12:37 PM
z6hatchboy's Avatar
^x2. base/intial timing must be corrected the right way by taking the belt off. Do it once, do it right
Old 01-27-2009, 09:22 AM
EX-T's Avatar
KeithsDAteg
11-29-2009 05:32 PM
Salsa
02-28-2009 11:31 AM
zensoku207
03-21-2005 10:48 PM
honda8882
09-29-2002 11:28 AM
Quick Reply: Timing question...
