500whp h22 stock ignition possible?
i have a fully built h22a made 410whp with a sc34 turbo and log manifold at 18psi now im looking for 500 with a ramhorn and a gt35r but im worried about the ignition. I made 410 with a stock igntion and blaster coil. I wanted to install a msd ignition but the tuner told me i dont need it and it might create conflicts with my hondata200. Should i get a ignition for 500whp on 94octane or leave it stock?
Re: 500whp h22 stock ignition possible? (rick22snail)
how high are you revving?
yes 500 is possible with stock ignition,,ive personally seen cars at the track make more power then that with stock ignitions
Re: 500whp h22 stock ignition possible? (ItzTw)
where did you pull those numbers from?
we have made in the 450 range on 100% stock ignition on pump.......and every h22 i have ever seen with MSD just has nothing but problems. i hate MSD
Re: 500whp h22 stock ignition possible? (Turbo-charged)
well like i said i made 410 and never had ignition problems just missfiring when i made 300whp so i just put ngk7s instead of 8s. Is there anyone producing over 500 on a h22 with stock ignition in this forum? I tried searching especialy for 93h22acx's setup and he never mentioned a msd ignition on his setup
i ♥ snails
Stock ignition has been proven time and time again. its not the horsepower usually its the Rpms that cause honda iginitions to become unaccurate but at the 8500 rpm rnage the stock ignition should be accurate and keep up. Sorry to thread jack but has anyone used MSD's new distributor?
sorry for opening an old *** thread but the stock ignition will not break-up at 380whp...lol
im running an old dizzy,old plug wires and bkr7e plugs making 550~whp and revving to 8700 with my h22. no issues at all..
Moderator
That doesn't mean it can be maintained. There's a difference between "revving" and maintaining higher levels of power for a particular purpose.
So yes, it can, but it depends upon what its used for.
Thanks for bringing that back up. This goes for ALL ignitions, not just the H-series.
NA_H22_Ej8
20
02-14-2006 05:59 PM
BB6-213
08-17-2005 05:05 PM
