integra starting issue
Old Dec 27, 2007 | 07:12 AM
fullboostin's Avatar
Default integra starting issue
I have a 92' integra and ever since I bought the car I have been experiencing a starting issue. The car never starts on the first try. If i pump the clutch for the clutch switch to engage more than once it will usually turn over and start perfectly after the 2nd or 3rd try. Does anyone know what this problem could be? Possibly starter, clutch switch or battery? Any help would be appreciated.
Old Dec 27, 2007 | 01:58 PM
Perfectionist's Avatar
Default Re: integra starting issue (fullboostin)
Not enough information provided to give an opinion. If there is a no crank situation, say so. A battery problem wouldn't allow it to "start perfectly".
Old Dec 27, 2007 | 02:24 PM
Default Re: integra starting issue (Perfectionist)
If i turn the key it will just click. If the key is held in the start position and the clutch is pumped several times, it will then turn over and start fine. It will either click or turn over. There is no in-between or hesitations.
Old Dec 27, 2007 | 02:55 PM
brzrkr's Avatar
sounds like the starter if it just clicks, same problem i had on my dc2 and ever since i rebuilt my starter, no problems what so ever
Old Dec 27, 2007 | 04:21 PM
zuum's Avatar
well it could be several things... anything in the starter circuit, if there is corrosion in the clutch switch that could be a problem, or the starter solenoid, try it without pumping the clutch doing everything exactly the same way.
Old Dec 28, 2007 | 05:29 AM
Default Re: integra starting issue (zuum)
If I dont pump it, it just clicks.
Old Jan 2, 2008 | 05:49 PM
sounds like I will try and replace the starter.
Old Jan 4, 2008 | 08:31 AM
anyone else?
Old Jan 4, 2008 | 03:49 PM
aca's Avatar
aca
dont just change the starter its easy to test. first make sure the battery is ok. if you dont have a batt tester then get them to test it at auto zone. if the batt is good, check the starter w/ a test light. touch it to the little starter terminal then get someone to turn the key. if there is light the starter is fine... unless the clutch switch is bad. and clutch switches are EASY to fix. just cut the wires and twist them together. if that doesnt work untwist them and make sure they arent touching. essentualy what you are doing is taking the switch out of the equasion.
also, there is a clutch switch adjustment you might play with before you get to excited. might be the whole problem.
magicmyst98
14
Sep 2, 2013 12:06 PM
viera
Sep 18, 2011 08:02 PM
morganm58
Sep 10, 2010 06:59 AM
Joe...
Nov 28, 2006 10:14 PM
yellowmonkeyboy
Jul 10, 2005 08:55 AM
