Oil restriction
Old Jun 6, 2004 | 06:39 AM
97F22B2's Avatar
Default Oil restriction
Every time i let my car sit for a little while and the oil pressure gets high like when i first start it in the morning, i think myoil feed line is allowing too much pressure get ot the turbo and the selas are giving out. I mean its seeing like ubove 70 psi and blowing smoke everywere. Anyone know of a good sight for a DIY oil restrictor or somehting i can buy cause i need one badly. Plus i mught wanna try and change my oil drain too.
Old Jun 6, 2004 | 08:34 AM
HXMan's Avatar
Default Re: Oil restriction (97F22B2)
I bought an autometer 1/8npt to -4an fuel restrictor fitting (ATM-3277 summit part number), and had the hole drilled out to .060". I am going to use that as an oil restriction. I am going to have a pressure gauge after the restrictor so I will let you know how it works out. If it doesn't work I also bought a 5 dollar needle valve at a hardware store.
Old Jun 6, 2004 | 08:36 AM
Pengo's Avatar
what size is ur feed line?
Old Jun 6, 2004 | 08:54 AM
tolowhb's Avatar
Default Re: Oil restriction (Pengo)
I know the oil pressure in my car usually goes pretty high when I first start it but once it warms up it goes down. Probably no help to you though.
Old Jun 6, 2004 | 10:47 AM
97F22B2's Avatar
Default Re: Oil restriction (tolowhb)
yea it goes down after awhile but id like to get this thing so it wont see more than 30 PSI no matter what to see if its my turbo that making the smoke or somehting else. Either way i still need to restrict the amount of oil its seeing
Old Jun 6, 2004 | 05:48 PM
integramic's Avatar
I nwas told you can put a nitrous jet in the line to restrict it. You can even get any size to go up or down in pressure.
Old Jun 7, 2004 | 06:11 PM
97F22B2's Avatar
really, got any more info on this?
Old Jun 7, 2004 | 06:41 PM
djfob's Avatar
I'm using one of these and an oil pressure gauge to adjust pressure.
HXMan's Avatar
Default Re: (97F22B2)
He just suggested pretty much the same thing I did above.
Old Jun 9, 2004 | 05:18 PM
97F22B2's Avatar
were can i get one at?
Old Jun 9, 2004 | 05:41 PM
djfob's Avatar
this is where I got mine
http://www.homemadeturbo.com/f...15072
Old Jun 10, 2004 | 08:29 PM
97F22B2's Avatar
Default Re: (djfob)
thank you much
xkrazyxjbrkerx75
Aug 9, 2011 02:47 PM
hotshot100
Apr 14, 2010 05:10 PM
NIGHTRIDER27
Apr 9, 2008 06:51 PM
importdude2000
Jul 6, 2006 04:09 PM
CzanSOHC
Jan 29, 2003 09:36 PM
