Reducing weight?
Old Oct 25, 2004 | 10:28 PM
  #26
bad-monkey's Avatar
Default Re: Reducing weight? (BolivianFuego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Yea, i heard from a frined that its better to keep the battery in the middle of the car instead of the back where most people relocate their batteries. Is this true seeing how your a avid auto x'r/ road racer im guessing. Is there any fact in this statement? He said to keep it neutral. </TD></TR></TABLE>
it depends on the rest of the car, as you can imagine. the problem with relocating the stock type battery into the cabin is that there's a ventilation issue with the stock battery and you may or may not be breathing in some pretty nasty **** if you put it in the cabin.
as far as vehicle weight distribution is concerned, the ideal weight dist. for a FF car is somewhere in the neighborhood of 55%F/45%R in some of the studies i've seen. so moving it to the middle vs. the rear may or may not affect this percentage. still more, driver preference plays into this equation alot, some people like loose and others like looser, so it depends. also suspension settings, tires, camber settings etc etc will likely play a much bigger role in determining the handling characteristics of the car than 400 lbs-in of moment (40 lbs x 10")
i wish being avid meant i could actually get out and drive more. but between school and my collection of CEL's and other little car problems...
Old Oct 25, 2004 | 10:32 PM
  #27
BolivianFuego's Avatar
Default Re: Reducing weight? (bad-monkey)
Thanks for the response. That cleared it up somewhat, showing me its just not as simple as i thought.
Old Oct 25, 2004 | 11:05 PM
  #28
eMpAtHy's Avatar
Default Re: Reducing weight? (vtec92lude)
you can take almost everything out...you can rip out your speakers and headunit if you can go without music. rip your seats out if you wont ever be driving anyone..rip out carpet..u can even take out your shift *** and just use the stick. you can take out cruise control, abs, power steering, ac, and a whole lot more. decide what you want and what you want to sacrifice.
Old Oct 26, 2004 | 12:03 AM
  #29
vtec92lude's Avatar
I also know that 100lbs is enough weight to make a difference. My wife weighs 110 and when she is with me I can litterally feel a difference. I know I can cut 200lbs from my car without loosing driveability and that is my plan. I own a base S 92 Lude and really want to get it to about 2450. Keeping my back seat and all panels (to keep my stock appearance).
Old Oct 26, 2004 | 12:36 AM
  #30
bad-monkey's Avatar
200 lbs is a little ambitious.
if you've got a sunroof, getting a CF plug for that will get you around 30 lbs off if the motor for the 'roof comes out along with the panel.
hawker genesis lightweight battery (13 lbs) vs. the 42 lb stock battery is another 29 lbs.
CF hood cuts another 30 - 40 lbs.
12 lb 15" rims cuts ~28 lbs
aftermarket SS exhaust is about 10 lbs lighter than oem
spare tire/tools ~20 lbs ?
aftermarket header is about 5-10lbs lighter than stock
lightweight bucket seat is 30 lbs lighter than oem
so far the running total is: 182 lbs and relatively comfortable.
these figures are off the top of my head, and might be somewhat inaccurate, but they're close enough to get an idea of what you could do to shave some weight.
beyond these things it gets pricey or uncomfy.
Old Oct 26, 2004 | 05:36 AM
  #31
boostinh22
Guest
Posts: n/a
i've removed/substituted with something lighter:
back seats
spare tire/jack
sound deadening material
cf hood
heat shield from header
shock absorber thing on front bumper
that's most of it. i'm down to just under 2900 lbs with full tank of gas. i'm running 14.70's and beating cars that i shouldn't be, like b18 hatches and built n/a si coupes that supposedly run 13.80's. and all of this with only intake and exhaust on a base 5th gen 5spd. i think weight reduction does a lot more than some of us think. the prelude is a heavy car and this is a great way to get faster and surprise some people.
Old Oct 26, 2004 | 07:28 AM
  #32
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">200 lbs is a little ambitious.
beyond these things it gets pricey or uncomfy.</TD></TR></TABLE>
Yea those numbers seem about right.
Old Oct 26, 2004 | 08:49 AM
  #33
ChrisRicketts's Avatar
who wants a battery sitting right next to them when they're driving down the road. not me.
Old Oct 26, 2004 | 08:56 AM
  #34
Default Re: Reducing weight? (ChrisRicketts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">
who wants a battery sitting right next to them when they're driving down the road. not me.</TD></TR></TABLE>
Just all on how much your willing to sacrafice, and if your car is an all out track car.
Am i right Mr. Ricketts?
Old Oct 26, 2004 | 11:03 AM
  #35
bb6h22a's Avatar
Depends on what thedesired static weight distribution is and what the intent is; mots people move the battery to the mid - line / back of the car to get weight off the front axle - then again, I just replaced my giganto 50 lbs battery w/ a 12 lbs dynabatt and don't need to worry about moving anything anywere, since I can balance out 12 lbs much easier than 50 lbs.
Old Nov 3, 2004 | 05:43 AM
  #36
john d
Guest
Posts: n/a
Default Re: Reducing weight? (egizzle6)
heres what i have on my kinda daily:
CF hood
no a/c
no balance shafts
no p/s
no cruise control
no spare/jack
no carpet or anything in the trunk/ except battery
front shock aborber thing in the front bumper
no center console
and some other stuff i cant remember
BUT...sadly all this weight is gunna get added back on when my turbo set is done, manifold,turbo, intercooler, ect....
Old Nov 3, 2004 | 07:51 AM
  #37
Default Re: Reducing weight? (john d)
On what car is this?
Old Nov 3, 2004 | 08:59 AM
  #38
john d
Guest
Posts: n/a
5th gen prelude for now, but soon im gunna drop it in a hatch when i find another h22 for my prelude
Old Nov 3, 2004 | 09:07 AM
  #39
Wow. I plan to run a 5th gne exactly like you, Go get it weighed and let me know how much you got going there. O yea also go with a 1/8th tank of gas for your boy bolivianfuego.
Old Nov 3, 2004 | 09:18 AM
  #40
somboa's Avatar
John D, how heavy is your car now? Do you daily drive it? How liveable is it without PS? Do you parallel park much?
Old Nov 3, 2004 | 09:43 AM
  #41
mgags7's Avatar
w/o ps on a car that is meant to have ps is hell. i have done it before and its not pretty, parallel parking will be unheard of, and unless your goin over 20mph, turning the wheel will give you a good workout.....
im thinking along the same lines as the others, but i wouldnt get the sunroof plug, for 30 lbs...i love driving with it open....but i guess thats just opinion and doesnt really add much insight....hmm
edit: a couple people said stuff about a carbon trunklid for preludes, anyone know one for 4th gen with a website or phone #??
Old Nov 3, 2004 | 09:46 AM
  #42
Default Re: (mgags7)
On my friends Teg it has no AC and PS it feels exactly if not easier then my hatch back. If i would do it to a lude i would do exactly what my friend did to his ride and strip the uneeded stuff so it could be nice and light to turn.
Old Nov 3, 2004 | 10:59 AM
  #43
john d
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Wow. I plan to run a 5th gne exactly like you, Go get it weighed and let me know how much you got going there. O yea also go with a 1/8th tank of gas for your boy bolivianfuego. </TD></TR></TABLE>
i plan on getting it weighed very soon, b/c i am too interested in the weight. i also forgot to mention i dont have a spoiler either. but bolivianfuego, can bet your last dollar ill be riding with an 1/8th tank or less, i ride like that no matter what hehe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by somboa &raquo;</TD></TR><TR><TD CLASS="quote">John D, how heavy is your car now? Do you daily drive it? How liveable is it without PS? Do you parallel park much? </TD></TR></TABLE>
yes i daily drive it, (except when its really hot) actual in car drive time for me like less than an hour a day (school/work) until like 5pm when my dad brings his work truck home and i just use that its VERY liveable w/o PS its the same thing as having PS when you get rolling, also works them guns and i never parallel park
Old Nov 3, 2004 | 11:02 AM
  #44
Holy ****. Your my evil twin. I used to roll like that evey where cause i was always ready to run someone. My friends called me crazy but i just thought i had *****. Man seriously though your setup is exactly what i plan to do soon enough, minus the turbo setup. Im probably going to gut the sound deadening also though. no airbags no ac no PS. Might keep sunroof though, they make the prelude.
Old Nov 3, 2004 | 11:07 AM
  #45
john d
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Holy ****. Your my evil twin. I used to roll like that evey where cause i was always ready to run someone. My friends called me crazy but i just thought i had *****. Man seriously though your setup is exactly what i plan to do soon enough, minus the turbo setup. Im probably going to gut the sound deadening also though. no airbags no ac no PS. Might keep sunroof though, they make the prelude. </TD></TR></TABLE>
haha you shoulndt of said that now they are gunna change our titles to the olsen twins hahahaha you can be the one with the drug problem hell yeah, not to be a ricer but gas = weight and i figured might as well ride close to empty cuz our cars are heavy in the first place. but yeah im in the process of trying to make air bag "trays" since no1 makes them for our car. but check out my motor build... i dont think i can turn back now with 9:1 compression https://honda-tech.com/zerothread?id=1030700
Old Nov 3, 2004 | 11:11 AM
  #46
Well with that said, i was wondering, cant you just undo the top piece of the passenger Airbag and use that to fill up the hole. Cause i swear that piece slides off.
spintboy
Jan 1, 2008 09:40 PM
envision
Dec 13, 2007 02:55 PM
danny98r
Jun 9, 2005 03:25 PM
eumoria
Sep 14, 2004 04:46 PM
GsR HtCh
18
Dec 19, 2003 08:12 PM
