OEM Piston
Old Dec 12, 2002 | 10:54 PM
HondaH22A's Avatar
Default OEM Piston
Hi, in the Honda parts catalog for OEM piston. They have piston set A, set B, and OS. I know the OS is the oversize but what's the difference between piston set A and set B? How do you know which piston set that will fit into your engine? Thanks.
Old Dec 13, 2002 | 04:51 AM
DarkJedi's Avatar
Default Re: OEM Piston (HondaH22A)
its stamped on your block, like BAAA
2 factory sizes, all preludes have different combinations of pistons.
size B is smaller of the two
Old Dec 13, 2002 | 10:33 AM
HondaH22A's Avatar
Default Re: OEM Piston (DarkJedi)
Where can I find the stamped? Is it near the H22A stamped?
Old Dec 13, 2002 | 11:01 AM
Boostless97Lude
Guest
Posts: n/a
bottom right corner of pic...
Old Dec 13, 2002 | 01:25 PM
BoostedH23a1's Avatar
Default Re: OEM Piston (Boosted97Lude)
**** u sam...... help me buy some sleeves....
Old Dec 13, 2002 | 08:01 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: OEM Piston (BoostedH23a1)
maybe i will..... when i win the SC lottery
Old Dec 13, 2002 | 11:17 PM
HondaH22A's Avatar
So does it matter if I use A or B if I want to do an oversize for my block? The A and B is only available for the standard size piston, isn't it? Not for the OS piston?
Old Dec 14, 2002 | 05:01 AM
Boostless97Lude
Guest
Posts: n/a
no, A and B are not used for oversized, but if your pistons are already A, then it is pointless to bore over, b/c you will only be going larger by .005mm
Old Apr 13, 2011 | 09:12 AM
DOHCterJEREMYb's Avatar
sorry but i just want to make this clear, so if its stamped BAAA then buy SET A? and if its BBBB then buy SET B?
Old Apr 13, 2011 | 03:34 PM
Mike95lude's Avatar
Well if you don't want to do a hone, just match the exact combination of "B" and "A" pistons that it came with. That's what I did on my H22A1 when we swapped in Type-S pistons.
Old Apr 13, 2011 | 05:21 PM
gstrudler's Avatar
How was your taper and P2W? I've heard FRM cylinders are pretty notorious for going out of round with any amount mileage.
Jeremy, as Mike said, you would buy one "B" piston and 3 "A" pistons; they are usually sold individually, not as a set from the dealer. The piston "set" in the catalog I believe refers to a single piston & rings, and possibly wrist pin and clips.
Old Apr 14, 2011 | 08:00 AM
well on the catalog it says QTY 4 on each set but any way my block is stamped BBBB i just wanted to make sure and you guys helped me out alot thanks for making this alot more clear to me
Old Apr 14, 2011 | 08:36 AM
only thing that confuses me now is weither they sell them in a set or in singles? because it says set?
boostedb20z
Feb 10, 2008 12:38 PM
2trix
Mar 30, 2004 02:26 PM
turboex
Mar 1, 2004 11:11 AM
DLB1994
Jul 4, 2002 02:33 AM
