Spring Compressor??
Old Nov 27, 2005 | 02:12 PM
mike9571's Avatar
Default Spring Compressor??
Im planning on putting some H&R springs on my DA and im just wondering if i need a spring compressor to take of the originals and obvisouly to put on the new ones???...thanks
Old Nov 27, 2005 | 02:17 PM
integra3586's Avatar
Default Re: Spring Compressor?? (mike9571)
you will need a spring compressor to remove the stock springs safely usually u dont need any kind of spring compressor to put the new lowering springs on
Old Nov 27, 2005 | 02:18 PM
Default Re: Spring Compressor?? (integra3586)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 &raquo;</TD></TR><TR><TD CLASS="quote">you will need a spring compressor to remove the stock springs safely usually u dont need any kind of spring compressor to put the new lowering springs on </TD></TR></TABLE>
Old Nov 27, 2005 | 02:32 PM
Liquid Ice NF's Avatar
watt?? i had to use it to take the old off and put the new ones on...
Old Nov 27, 2005 | 02:36 PM
mike9571's Avatar
Default Re: Spring Compressor?? (Liquid Ice NF)
sounds good...im using the race springs so i prob wont have to use the compressor to put them on....thanks
Old Nov 27, 2005 | 02:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquid Ice NF &raquo;</TD></TR><TR><TD CLASS="quote">
watt?? i had to use it to take the old off and put the new ones on...</TD></TR></TABLE>
i said usually, i am going off my personal experience. i have installed a lot of lowering springs, and i have not had to use a spring compressor on any of the setups i worked on,
obvioulsy it depends on how much of a drop it is, my experience was with 2-3 in drops, tenzo r, neuspeed, matrix, tokico
Old Nov 27, 2005 | 03:01 PM
Monkey Z.'s Avatar
since DA springs arn't compressed as much as lots of cars you can put the spring/shock assembly sideways and put a skateboard on top of the spring and make it work like a blocker that's what i did (don't blame me if you get hurt though)
Old Nov 27, 2005 | 04:06 PM
Default Re: (Monkey-DA)
a skateboard lol
i used a wheel barrel as a precaution.
Old Nov 27, 2005 | 07:57 PM
Sam92Teg's Avatar
Default Re: (Liquid Ice NF)
I installed some Nuespeed Sport springs without a spring compressor, there wasn't that much pressure on the original springs. I just used a towel wrapped around the shock/spring assembly and backed off the top retainer bolt. It was cake, and putting the Nuespeed spings on my AGX's just took alittle pushing to get the top nut started. No need for a spring compressor on my 92 RS.
Old Nov 27, 2005 | 08:14 PM
Integra_drk's Avatar
id get it to be safe. wont need it to put the new ones on.
Old Nov 28, 2005 | 06:34 AM
shyboi4u's Avatar
i used to let the springs shoot out. i had my foot on the bottom end of the shock and then loosen the bolt and then had a bucket on the other end to catch everything. i did that on all the cars i dropped. except for when i did a '02 accord V6. i wasn't gonna risk doing that. also the spring to big. anyways, use the compressor. i haven't had to use to compressor to put lowering springs back on.
Old Nov 28, 2005 | 06:40 AM
mmuller's Avatar
Mad Scientist
Default Re: Spring Compressor?? (nothinginteresting)
go buy a freaking spring compressor....they are cheap...
stock springs are the ones pre-loaded, buy the tool now you will thank yourself when you use it again
Old Nov 28, 2005 | 12:22 PM
Default Re: Spring Compressor?? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">go buy a freaking spring compressor....they are cheap...
stock springs are the ones pre-loaded, buy the tool now you will thank yourself when you use it again</TD></TR></TABLE>
i know u can rent them from autozone.. well actually yu put a deposit down.. and u can keep them if u want.. but dont, cuz they charge like $40
Old Nov 28, 2005 | 01:12 PM
mike9571's Avatar
yea thats what i did for my chevelle i kept the compressor....only its an internal spring compressor.....i mine as well buy one for the friend who one day will need it
HondamanXxX
19
Jun 21, 2007 04:30 PM
Dee A Nine
Aug 29, 2006 04:27 PM
Blazin Civic
Suspension & Brakes
15
Jun 20, 2005 05:53 AM
dungsta
Suspension & Brakes
May 2, 2005 10:34 AM
CRX-RX
Jan 23, 2002 10:49 AM
